blower problems for heater- A/C on '91 explorer
Old 10-25-2002, 02:19 PM
reberhardt's Avatar
reberhardt
reberhardt is offline
Old 11-07-2002, 01:49 AM
hundehus's Avatar
hundehus
hundehus is offline
Hey I have a quick question.
The blower on my 91 explorer has been acting up lately. The heater and A/C work great but the blower doesn't turn on all the time. Sometimes it will turn on when you start it and sometimes it wont' come on until you are almost to your destination. It can be a hazard now that winter is here and need the heat and defrost. I would like to solve this problem myself. Got any good ideas?
Thanks!
Brad
Old 11-07-2002, 03:09 AM
marragtop's Avatar
marragtop
marragtop is offline
When you're having the problem, do any of the speeds on the blower work?? If not, it sounds electrical, or perhaps the motor is locking up. Try rapping on the motor to see if that gets it going. That may help you further diagnose the problem.
Mike
Old 11-07-2002, 09:09 AM
Opera House Works's Avatar
Opera House Works
Opera House Works is offline
Located with the speed control resistors, there is a thermal fuse. This is the same kind as in hair dryers and coffie makers. Radio Shack sells replacements for about $2. Because it is chemical, some can become intermitant when old. Looks like a metal diode. If it is bad, crimp a new one in. Soldering will pop it!
Old 11-08-2002, 09:08 PM
lself62's Avatar
lself62
lself62 is offline
A co-worker had the same problem . . . I suggested cleaning the ends of the armature in the bushings. He did it the easy way and says he has had no problem for a month now. He simply drownded the bushing areas with WD40. He got a lot of black run off and put the blower ***'y back in. He's happy for now. I wouldn't expect this to be a permanent fix but it should get you going quick and cheap and actually last a good while. Possibly a couple years.
LS
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: blower problems for heater- A/C on '91 explorer
