blower problems for heater- A/C on '91 explorer - Ford Truck Enthusiasts Forums
Old 10-25-2002, 03:19 PM
reberhardt reberhardt is offline
reberhardt is starting off with a positive reputation.
Old 11-07-2002, 02:49 AM
hundehus hundehus is offline
hundehus is starting off with a positive reputation.
Hey I have a quick question.
The blower on my 91 explorer has been acting up lately. The heater and A/C work great but the blower doesn't turn on all the time. Sometimes it will turn on when you start it and sometimes it wont' come on until you are almost to your destination. It can be a hazard now that winter is here and need the heat and defrost. I would like to solve this problem myself. Got any good ideas?
Thanks!
Brad
Old 11-07-2002, 04:09 AM
marragtop's Avatar
marragtop marragtop is offline
marragtop is starting off with a positive reputation.
When you're having the problem, do any of the speeds on the blower work?? If not, it sounds electrical, or perhaps the motor is locking up. Try rapping on the motor to see if that gets it going. That may help you further diagnose the problem.
Mike
Old 11-07-2002, 10:09 AM
Opera House Works Opera House Works is offline
Opera House Works is starting off with a positive reputation.
Located with the speed control resistors, there is a thermal fuse. This is the same kind as in hair dryers and coffie makers. Radio Shack sells replacements for about $2. Because it is chemical, some can become intermitant when old. Looks like a metal diode. If it is bad, crimp a new one in. Soldering will pop it!
Old 11-08-2002, 10:08 PM
lself62 lself62 is offline
lself62 is starting off with a positive reputation.
A co-worker had the same problem . . . I suggested cleaning the ends of the armature in the bushings. He did it the easy way and says he has had no problem for a month now. He simply drownded the bushing areas with WD40. He got a lot of black run off and put the blower ***'y back in. He's happy for now. I wouldn't expect this to be a permanent fix but it should get you going quick and cheap and actually last a good while. Possibly a couple years.
LS
wheels 1973 - 1979 F-100 & Larger F-Series Trucks 7 04-13-2004 01:08 AM
is this common 1987 - 1996 F150 & Larger F-Series Trucks 3 11-12-2002 02:38 AM
Wheelbase 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-14-2002 10:06 AM
Overheating 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-11-2001 11:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
