Alternator Burned Out!!!! - Ford Truck Enthusiasts Forums
Old 06-24-2004, 10:47 AM
1990Fordf150v8 1990Fordf150v8 is offline
1990Fordf150v8 is starting off with a positive reputation.
My question is well today I smelled wires burning and looked under the hood and the alternator was smoking from the big connector where it go's in, I pulled on it and the whole connector came out all melted. But all that is melted is the alternator part of the connecter that is in the alternator, nothing else not even the wires going to it. So what is going on? Did my alt. short out? Please let me know what all you think.
Old 06-24-2004, 12:37 PM
trike1946's Avatar
trike1946 trike1946 is offline
trike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud of
I went through three alternators in two years on my 92. Seems like they just short out now and again. Buy one with a lifetime warranty and you will be covered if it happens again. Good luck.
Old 06-24-2004, 12:46 PM
trike1946, did your's do the same thing as i said mine did?
Old 06-24-2004, 01:29 PM
larry derouin larry derouin is offline
larry derouin is starting off with a positive reputation.
You need to get a NEW CONNECTOR! The wiring on the Ford's are notoriously small for the loads they have to handle and they tend to melt.
Cal Term 08622 is the # for the pigtail. The wiring is at least 1-2 gauge larger than original wiring. Also you can change out the Rectifier bridge / diode set cheap.
Replace the voltage Regulator, Brushes and the Diode pack/rectifier bridge while you have it apart. Clean up the commutator lands (where the brushes sit). Spray it all down with electrical equipment cleaner and a toothbrush to get all teh carbon out. Make sure when you put the rectifier bridge and the voltage regultor in, that the METAL SIDE has a light coating of heat sink grease (same stuff you put on your CPU and cooling tower on your computer.) or the parts will get overheated and you'll be right back where you started.
OR if you're mechanically stunted, go buy a new alternator AND the pigtail. Install as per instructions. I use non insultated butt connectors(crimps), then solder them, then heat shrink each individual wire, then wrap in electrical tape. Makes for a solid connection and it won't burn out.
That's my story and I'm stickin to it!
Larry
Old 06-24-2004, 01:51 PM
zieg96 zieg96 is offline
zieg96 is starting off with a positive reputation.
The 91 I am parting out did the same thing. Great info on the fix to keep it from doing it again. Thanks
Old 06-24-2004, 03:49 PM
It's not the wires or the connector it's the connector inside the alt. that melted
Old 06-24-2004, 03:53 PM
Sounds like you lucked out. Mine was toast, both the connector and alternator were crispy.
Old 06-24-2004, 11:45 PM
ATCS2004 ATCS2004 is offline
ATCS2004 is starting off with a positive reputation.
Replace the alternator and the connector going to it. This has been a problem with these for quite sometime. If you get an alternator from NAPA the connector comes with the new one and it tells you to replace it. Make sure you use the silicone gel that comes with it when installing the connector to the alternator. That will help reduce the heat.
Old 06-26-2004, 12:31 AM
1990fordf150v8.....the connector INSIDE the alternator is part of the Rectifier. See my previous for repair / replacement.
Old 06-26-2004, 04:58 AM
200000+F150 200000+F150 is offline
200000+F150 is starting off with a positive reputation.
You might have to do some looking in your area to find an alternator shop that will sell you parts, but if you are mechanically inclined this is the way to go. Individual parts at such places are cheap and if you do it right you'll have a better alternator than the "cheapies" at the chain parts stores. See Larry's post above. Good advice, and this is what I always do. I'm a regular customer at an alternator shop here in Nashville and I can go through one for about $40 or less and rebuild it in about an hour. They'll likely have the harness side connector too if you need that.
Old 06-26-2004, 05:41 PM
kinnja kinnja is offline
kinnja is starting off with a positive reputation.
A friend of mine had a 90's F150 that was constantly going through batteries and alternators. He said it was because someone sold him the wrong belt for it. He doesn't remember the exact year of the truck.
HTH
Old 06-27-2004, 01:14 AM
Show-N-Go LX Show-N-Go LX is offline
Show-N-Go LX is starting off with a positive reputation.
Quote:
My advice to you is to ditch the stock "2G" alternator altogether and upgrade to a later model 130amp "3G" alternator from a 94-95 Mustang GT. The 2G alternator is good for NOTHING other than risking burning down the whole front end of your truck thanks to the faulty rectifier plug. I have done this swap to both my 1992 F150 5.0 and my 1990 Mustang LX 5.0 and the 3G will quite simply handle just about any electrical load you can throw at it.
Old 06-27-2004, 02:19 AM
beerinside beerinside is offline
beerinside is starting off with a positive reputation.
Is the 3G a direct bolt-up part? I just had the alternator in my 88 fry the other day and I replaced it with the one from my 92 parts truck. I have no doubt that it will happen again in the future.
Old 06-27-2004, 04:02 PM
Quote:
Pretty much- you have to grind away a piece of the ribbing inside the alternator bracket, then it bolts in with no problems. As far as wiring it up, you have to cut off the old rectifier plug and attach eyelets to the two 10-gauge wires so that they can go on the threaded post on the back of the 3G alternator. The little black/white 16-gauge wire that was on the rectifier plug goes to the gauge/light plug on the side of the 3G, and you reuse the voltage regulator plug, as it is the same on the 3G.
Old 07-08-2004, 02:03 AM
Schmids4.9l's Avatar
Schmids4.9l Schmids4.9l is offline
Schmids4.9l is starting off with a positive reputation.
Cool
Maybe your ****in voltage regulator is dickin up, Damn thing burnt up a brand new ****in battery in mine.
Burning through 3G alternators - Help! guisepi Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 07-20-2015 01:44 AM
Low batt. charge after injector install... Brown Falcon 1994.5 - 1997 7.3L Power Stroke Diesel 3 05-31-2010 09:06 PM
what's the deal with the goofy alternator wiring? caddywhompus 1978 - 1996 Big Bronco 2 11-24-2004 01:48 PM
powermaster alternator? (uh-oh) monkei 1978 - 1996 Big Bronco 13 02-26-2004 04:40 PM
powermaster alternator? (ummm) monkei Electrical Systems/Wiring 1 02-19-2004 07:58 PM
Tags
2002, 3g, alternator, bridge, burnt, diode, f150, ford, fry, napa, plug, rectifier, remove, replace, shorting, smells, wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
