1978 GT electrical problems - Ford Truck Enthusiasts Forums
Old 06-23-2004, 11:23 PM
qbanmom qbanmom is offline
qbanmom is starting off with a positive reputation.
Unhappy 1978 GT electrical problems
Hi, this seems like a great sight and I am in need of some guidance. We bought a 78 ranchero gt for resale. We have done a little work, but still have the electrical to go and it seems like a nightmare. The previous owner rigged the wiring and it is very difficult to tell what is what. The only thing I do know is that nothing on the dash nor the headlights works. How much would it cost for someone to fix that? How difficult is it to do on ones own? Lastly, I live in the High Desert in southern california, is there and electrical wiz out there willing to take on the task for a reasonable $$ amount. Any info would help. Al
Old 06-24-2004, 08:47 PM
Dealford's Avatar
Dealford Dealford is offline
Dealford is gaining momentum as a positive member of FTE.
Welcome to FTE.
The very first thing you should do is buy a service manual for that truck. Not only will it get you through the repairs, it is a little added perk on the resale.
I'm nowhere near you, but there will be another member along soon that can help you some more.
AL.
Old 06-25-2004, 11:25 PM
grclark351 grclark351 is offline
grclark351 is gaining momentum as a positive member of FTE.
the manual is a good idea, it'll help you relate to what people suggest that you look at. like the fusible links at the starter solenoid. they have little flags molded onto them and tell the amperage. they are like an in-line fuse that burns out if need be to save the rest of the wiring. sometimes when they burn you can see it from the outside, sometimes you can't tell by looking. you can check them by testing for power by sticking the probe of a tester into the wire downstream of the fusible link. i think there may be more fusible links under the dash? not sure though, check the manual!
Old 06-26-2004, 06:22 PM
LocoC LocoC is offline
LocoC is starting off with a positive reputation.
I did some electrical work on a 79 Ranchero. Like your situation, some guy had done a total mickey mouse (and that's a compliment) job on the electrical. I found all sorts of wire that had to connections on either side, the window wiring was reversed. Either way, I had done some minor electrical work before, but nothing like this. I found that as I got into the wiring more and more, it became easier and easier. It's just a matter of matching lines a lot of the time, and making sure the lines aren't grounded anywhere. Also, the fusible links gave me a bit of trouble. I ended up replacing the one next to the solenoid with basically a mini circuit breaker that automatically resets itself. It works the same as the fusible link, but it doesn't burn out, just closes down and opens again. I put one of those breakers right before the switch for the headlights, since the wiring in the switch kept melting as a result of the halogens.
Old 08-01-2004, 11:19 PM
74fordtruck's Avatar
74fordtruck 74fordtruck is offline
74fordtruck has a great reputation on FTE.74fordtruck has a great reputation on FTE.74fordtruck has a great reputation on FTE.74fordtruck has a great reputation on FTE.
this is an old thread, so i may not get any help, but where would you get one of these circut breakers, and what kinda amp breaker would you put in? thanks
Old 08-02-2004, 06:00 PM
a good/real auto parts store, or an electrical supply house. i would only replace the fusible link with a breaker of the same volt/amperage as what the fuse link was originally. the amperage is on a small "flag" attached to the wire of the fuse link.
GT anyone???? shorangerbird Nite, Nascar & Other Limited Edition Ford Trucks 5 08-21-2015 04:05 PM
Dual fuel tanks, manual fuel pump-no electric nonrev321 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 07-31-2015 12:30 AM
Dual fuel tanks - manual fuel pump? nonrev321 Fuel Injection, Carburetion & Fuel System 1 07-24-2015 11:12 AM
What to do come spring and summer miner999r 6.7L Power Stroke Diesel 8 01-05-2015 08:02 PM
GT-40 heads and header compatibility Encho 1987 - 1996 F150 & Larger F-Series Trucks 4 08-20-2014 03:05 PM
Tags
qbanmom
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
