ranger rear end gear ratio? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 06-23-2004, 07:55 PM
rangastang5.0 rangastang5.0 is offline
rangastang5.0 is starting off with a positive reputation.
my dad owns a 97 ranger xlt sport, 5 spd, 2 wheel drive 4 cylinder, im wondering what the gear ratio is in the rear end, i was guessing 2.8, but im not sure, any info would help.
my second question..is there a rear end with positraction that will interchange with the current rear?
3d..is there a rear end or part available to lower the gear ratio?
thanx, any help would be appreciated..
Old 06-23-2004, 09:47 PM
BLAZING BLAZING is offline
BLAZING is starting off with a positive reputation.
First look at the tag on the rear end for the gear. I don't know about the second question. And third yes there is lower gears for that rear. Go to Randysringandpinion.com or you local performance shop and ask them.
Old 06-24-2004, 02:03 AM
NightReaver's Avatar
NightReaver NightReaver is offline
NightReaver is starting off with a positive reputation.
the sport package came with a 3.73 rear end (IIRC)
there are limisted slip rears in the aftermarket
and to lower your gears next step is 4.10 (I have this and love it)
4.10 = more torque less high end
Rear End Gear Ratio Corkwheats 1967 - 1972 F-100 & Larger F-Series Trucks 3 03-31-2013 12:27 PM
gear ratio identification blueovalbigblock 1973 - 1979 F-100 & Larger F-Series Trucks 0 04-21-2010 01:11 PM
C-6 Gear Ratios? banjopicker66 Clutch, Transmission, Differential, Axle & Transfer Case 7 01-20-2010 01:51 AM
What is my gear ratio? millwood1 Clutch, Transmission, Differential, Axle & Transfer Case 7 12-16-2003 07:29 PM
87 Ranger stock gear ratio??... NMStang218 Ranger & B-Series 3 08-16-2002 01:22 AM
Tags
2002, end, ford, gear, ranger, ratio, rear, tag
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
