Block drain plug
06-23-2004, 07:30 AM
on
Block drain plug
I need help in locating the block drain plug for a good coolant flush on my '94 4.0 in an AWD Aerostar. Has anyone had any sucess or is it nonexistant (Ford cost-cutting) Thanks, Dave
06-23-2004, 07:59 AM
No block drain plug on your '94. The cooling system is drained by way of a petcock located on the bottom of the radiator.
06-23-2004, 09:35 AM
on
Thanks, quite a bit of coolant remains even when the lower radiator hose is removed, just another " buy a new one" strategy.
06-27-2004, 08:08 PM
try draining it and fill it up with just plain water then start it and keep putting water too it until the thermistat opens and let it circulate a couple times then drain it again... do it a couple times and then drain and fill with 50/50 and your set.
Matt
29,
30,
40,
aerostar,
block,
drain,
ford,
location,
number,
part,
plug,
ranger,
taurus
