Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-21-2004, 10:47 AM
LimeyZ is starting off with a positive reputation.
Unhappy HELP - Ticking noise - exhaust manifold?
I've had this annoying ticking noise for some time now.....
It only happens under load, accelerating or driving up a hill. If sounds very similar to detonation (engine "knock") with it's frequency but I don't think it's that. I'm been reading about exhaust manifold bolts breaking - could this cause a ticking noise?
Anyone have any tests I could do? I'm not throwing any error codes for either engine off or engine running.
1995 E150 5.8L V8
High top conversion van
55,000 miles
__________________
1984 F150 300cid Manual
1995 E150 5.8L Auto
2002 Escape 3.0L
  #2 (permalink)
Old 06-21-2004, 03:24 PM
ken04's Avatar
ken04 is starting off with a positive reputation.
1995 E150 5.8L V8
55,000 miles
Normally exhaust leaks go away after the engine gets warm enough to swell the metal exhaust parts. The small blocks were also almost as famous as the big blocks for cracking manifolds. I haven't heard of broken bolts on the older engines, just on the newer modular motors. Pull your doghouse and look at your manifolds. When your engine is cold, fire your engine with the doghouse off, you will be able to tell if you have manifold leaks. It sounds like pre-ignition or detonation to me. Have you tried a higher octane gas ? See if that makes it go away if it's not the manifolds, Ken
__________________
Ken,
2006 Mustang GT pkg
Suzuki XL-7
Previous;
E-350 15 pa. V-10 XLT Clubwagon
93 E-150 Mark III
97 F-250 CC PSD 4X4
95 F-150 SC 4.9 I6 4X4
93 F-350 CC 7.3 4X4
91 F-150 SC 302 4X4
89 F-250 SC 460 4X4
86 F-250 SC 6.9 ATS turbo 4X4
  #3 (permalink)
Old 06-21-2004, 04:11 PM
Ken, I've not tried a higher octane, but that's a good thing to try.....
The ticking is always there the moment the engine fires up and I pull away.
The tone of the ticking (under load..) never changes between a cold engine on a January morning in Ohio and a hot engine after a 5 hour drive in July.
I even wondered if it could be a mechanical problem?
Do the fuel injectors ever make a clicking noise?
Paul
__________________
1995 E150 5.8L Auto
2002 Escape 3.0L
  #4 (permalink)
Old 06-21-2004, 05:43 PM
goofy173's Avatar
goofy173 is starting off with a positive reputation.
It's definitely broken exhaust manifold studs. Classic case
  #5 (permalink)
Old 06-22-2004, 07:40 AM
Assuming the worst, one (or more?) broken exhaust manifold studs, what are the consequences of NOT fixing this problem? Will it eventually lead to some serious engine/exhaust damage? I was leaving with the van for a short vacation in the Smokys in a few days - plenty of hill climbing there...
Paul
__________________
1995 E150 5.8L Auto
2002 Escape 3.0L
  #6 (permalink)
Old 06-22-2004, 12:23 PM
ken04's Avatar
Paul
Well technically, broken exhaust can burn the exhaust valves, just like running an engine without any exhaust manifolds. But believe me, there's lots of Fords running around with the same thing, mine had cracked exhaust manifolds for 100,000 miles. I can't say how long the engine lasted after I traded it in, but I had like 180,000 or so on it and it ran like a top. But it isn't a good idea to continue with a problem like that. Injectors can make a ticking noise but usually it's a lifter or valve adjustment. Sometimes lifters can partially collapse while still opening the valves enough to run. Good luck, Ken
__________________
Ken,
2006 Mustang GT pkg
Suzuki XL-7
Previous;
93 E-150 Mark III
97 F-250 CC PSD 4X4
93 F-350 CC 7.3 4X4
91 F-150 SC 302 4X4
89 F-250 SC 460 4X4
  #7 (permalink)
Old 06-22-2004, 06:11 PM
Wink Now we're getting somewhere!
goofy173 is on the money, well, almost...!!!
Just took the dog house off and checked all the exhaust manifold bolts - they seem okay but a little trace of black powder around passenger side rear bolt tells the story. I can push a .004" feeler between the manifold and the head next to the bolt! I guess this means the manifold is warped, yes?
I used a stethoscope around the rest of the manifold but found no leaks. So, off with the manifold I guess but not until after my trip to the Smokys next week. That should give me a little time to say prayers for easy bolt/stud removal.
Question:- Will it make any difference if I try to undo the bolts when the whole engine is hot?
Paul
__________________
1995 E150 5.8L Auto
2002 Escape 3.0L
  #8 (permalink)
Old 06-23-2004, 12:52 PM
ken04's Avatar
Paul
The black streaks is a definite sign, maybe it's a gasket either gone or not tightened ? Use heavy amounts of liquid wrench or something similar the day before you attempt exhaust bolt removal. I don't know if a hot engine as opposed to a cold engine will make any difference. I would guess yes for aluminum heads but if I remember, this is a 351W right ? Which has cast iron heads. Good luck, hopefully the bolt will twist right out first try and you'll have no problems. It never hurts to pray though, for anything,
__________________
Ken,
2006 Mustang GT pkg
Suzuki XL-7
Previous;
93 E-150 Mark III
97 F-250 CC PSD 4X4
93 F-350 CC 7.3 4X4
91 F-150 SC 302 4X4
89 F-250 SC 460 4X4
  #9 (permalink)
Old 06-23-2004, 01:56 PM
Gasket....? I didn't see any gasket! It must VERY thin and does not visibly protrude beyond the manifold flange edges. MMMmmm....!
Paul
__________________
1995 E150 5.8L Auto
2002 Escape 3.0L
  #10 (permalink)
Old 06-23-2004, 10:38 PM
goofy173's Avatar
The studs have streched and will eventually break.
  #11 (permalink)
Old 06-24-2004, 10:02 AM
Last night, for a short term fix (hopefully!) I cleaned the rusty leaky area, manifold and head, with a wire cup brush in my Dremmel and worked some JB Weld into the gap. This morning I cranked up the engine and had No leak = No ticking.
I'm not sure how long this band aid will last - maybe to the end of street LOL. I know it's crude but if it lasts for a week I'm be very happy. If it lasts for a month it will be a miracle!
Paul
__________________
1995 E150 5.8L Auto
2002 Escape 3.0L
  #12 (permalink)
Old 06-24-2004, 11:05 PM
goofy173's Avatar
I've been going to try it. I asked another guy that did that, how long it lasted and he said his lasted 150 miles the 2 times he tried it.
  #13 (permalink)
Old 07-03-2004, 08:26 PM
Well, for anyone remotely interested, I got 600 miles without any exhaust ticking at the manifold. After 950 miles there a very slight tick but nowhere near as bad as the original condition.
Paul
__________________
1995 E150 5.8L Auto
2002 Escape 3.0L
  #14 (permalink)
Old 07-07-2004, 12:18 AM
goofy173's Avatar
guess I'll need to try it. Bought the JB Weld 6 months ago but haven't used it yet.
  #15 (permalink)
Old 07-07-2004, 02:49 AM
pfogle's Avatar
Village Idiot
pfogle is gaining momentum as a positive member of FTE. pfogle is gaining momentum as a positive member of FTE.
There probably aren't any gaskets on the manifolds as they really aren't needed, when torqued down the cast iron mates to the non-warped cast iron exhaust manifold really well. I replaced one on my 87 F150 and didn't use a gasket, it didn't leak, it was the other broken manifold that was leaking.
__________________
1977 F350 Crew Cab, 460, C6 and 4:10 posi.
Life is like a roller coaster, Live for the ups.
Negativity begets hate, hate begets ignorance, ignorance begets stupidity. Don't be stupid.
If you have to ask "Will this hurt?" do not proceed!
Did you like my post or response? Shoot me some love! Click the "scales" beside my user name!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
