Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero and 1961 - 1967 Econoline
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-21-2004, 09:43 AM
Tank Tank is offline
Tank is starting off with a positive reputation.
1970 Ranchero headlight switch
Hello,
Does anyone have a diagram or can easily tell me how to remove the headlight switch assembly from the dash panel? My headlights are not working on my 70 Ranchero GT, I've checked and replaced all fuses, traced the wires, everything looks fine. I would just run them to a toggle switch, but you can't do that here in the county I'm in here in TX. Lights must work off the switch, and that's the last place I can think that I'd be having problems. Thanks! Post here, or email me at jammy_69@hotmail.com. Thanks again for any suggestions!
  #2 (permalink)
Old 06-21-2004, 12:33 PM
ZRX61 ZRX61 is offline
ZRX61 is starting off with a positive reputation.
I has the same problem with my '70. It turned out to be the floor mounted dimmer switch had shorted out. I found that out AFTER I replaced the dash mounted light switch. I bought the dimmer switch & the headlight switch at a local autoparts place for about $7 each.
The cable for the parking brake was right next to the dimmer switch & had rubbed thru the wires.
  #3 (permalink)
Old 06-21-2004, 12:38 PM
Thanks! I'll give that a try. I can get to that easier than I can the light switch.
  #4 (permalink)
Old 06-21-2004, 12:42 PM
Removing the headlight switch is a bit tricky, you have to push a tab up behind the dash (on the switch housing) to release the knob. Once ya pull that out it says in the manual that ya have to use a *special tool* to remove the bezel thing so the switch fall out the back of the dash. Once ya have the knob removed you can see that the only special tool needed is a large philips....
  #5 (permalink)
Old 06-21-2004, 12:47 PM
ok, just got the old one out from under the seat.....
The knob realse thing is in the middle, on the bottom of the switch. Small spring loaded doodad a bit les than 1/4in high. Just push it in & pull the knob out.
Made by Standard Motor Products: Part # DS148
Dimmer switch is Borg Warner: # DS109
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
