Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-20-2004, 08:10 PM
nickmobile67 is starting off with a positive reputation.
Question Vacuum leak from brake pedal?
I just noticed yesterday when my truck is running, you can hear a sucking sound coming from the brake pedal. It seems to change when you depress the pedal. When you shut it off it's most noticable, because you hear it leak down for several seconds. If you depress the pedal then it stops, but seems to pick up again after you release the pedal?
Is my booster going? Is there something else I can look into? The truck only has 43K miles! help!
__________________
First On Race Day
  #2 (permalink)
Old 06-20-2004, 08:12 PM
andym's Avatar
andym has much to be proud of andym has much to be proud of andym has much to be proud of andym has much to be proud of andym has much to be proud of andym has much to be proud of andym has much to be proud of andym has much to be proud of andym has much to be proud of andym has much to be proud of
A bad booster will do that. The diaphragm breaks down over time, drys out, leaks, etc. and sucks air through the vacuum line and into the intake.
Good luck with it, they're a real treat to change.
__________________
Andy
1989 F-150 XLT Lariat Shortbed 4x4 300/T-18/3.55
1990 Bronco Eddie Bauer 4x4 351/E4OD/3.55
Quote:
It often takes more courage to change your opinion than to stick to it.
Election 2008 results: World's worst job given to a black man.
  #3 (permalink)
Old 06-20-2004, 09:52 PM
Thats what I was afraid of. Sounds almost like it's leaking where the rod comes through the firewall. Is that possible? Would it hurt to just leave it? Tommorow I'll disconnect the booster and see if it stops. Could the check valve cause that?
__________________
First On Race Day
  #4 (permalink)
Old 06-20-2004, 10:38 PM
andym's Avatar
It won't hurt to leave it the way it is, you'll just have to push the pedal harder. If you decide to disconnect the booster altogether, you'll obviously want to plug the vacuum line with something.
__________________
Andy
  #5 (permalink)
Old 06-20-2004, 10:52 PM
Redneck-Cowboy's Avatar
Redneck-Cowboy is starting off with a positive reputation.
I've had the exact same thing going on with my 86, usually when your booster is going bad it hisses when you push the pedal, but we have it exactly backwards and the brakes work fine don't they? It's weird but I figured, "Ah hell, as long as the brakes work." I've had it doing this for well over a year and my brakes work just fine, I've searched for that leak and it's impossiable to find, but it's under there. I wouldn't worry about it, just turn up the radio. Glad I'm not the only one.
__________________
Redneck-Cowboy
86 F-150 4x4, 4spd w/ a 300, Headers, 500 cfm 4-barrel, D.U.I or "H.E.I" ignition/dist., mild cam with chevy rockers, steel timing gears, decked the block and head .015, bored .060, true dual straight 2.5" all the way back ( a little to snappy, but frickin LOUD)
  #6 (permalink)
Old 06-21-2004, 12:32 AM
82F100SWB's Avatar
82F100SWB is gaining momentum as a positive member of FTE.
Dighphram in the booster is going bad...
My 3/4 ton has a dual diaghphram unit...
I got sick of it hissing and making it idle like garbage, so I put a new one on...
__________________
86 F250 HD, 4x4/460/T19/44HD/10.25
82 F100/86 F350 4x4 460 with some goodies/T19 D60/welded 10.25/38.5 Boggers, mud racer/wheeling pig...
81 F100/86 F250 HD 4x4, 6.9/T19/D44 TTB junk/10.25. All smoke, no power, turbo no more...
And a couple Brand D's with early "C" power
It's not what you BUY, It's what you BUILD
  #7 (permalink)
Old 06-21-2004, 12:41 AM
Brettddglas is starting off with a positive reputation.
82f100 has a good point. Not only will it make you nuts but will also drive your fuel management system crazy. They actually arent all that hard so just bite the bullet and get it done. Took me about a half hour with air tools and the proper amount of liquid refreshment
Take care and cheers hope this helped.
  #8 (permalink)
Old 06-21-2004, 12:42 AM
oh, btw, just diconnecting and plugging the vaccuum line wont do it if the diapgragm is gone. The air is leaking around that.
  #9 (permalink)
Old 06-21-2004, 01:13 PM
Marcus Merritt is starting off with a positive reputation.
I just replaced my vacuum booster and master cylinder ($131 from NAPA) and it cured the hissing plus the truck starts and runs better now. Must have been sucking air back into the intake.
Now gotta adjust master cylinder push rod as front disks seem to be binding more than normal. Anyone have any suggestions on this problem?
  #10 (permalink)
Old 06-21-2004, 03:03 PM
I guess it's probably the booster. I pulled the check valve out and put a cap on it. Started it up and I didn't hear the hissing at all, even after I shut it off. Then when I pulled my cap off the check valve I heard it hiss, so the line and valve are probably ok. It looks like I can get just the booster for about $80, or with the master for $125. If I change it should I get the whole thing? I think I could probably leave the master and just change the booster.
Also, my ford shop manual shows a bendix single diaphragm and tandem diaphragm unit. What is the difference, how do I know what I have?
__________________
First On Race Day
  #11 (permalink)
Old 06-21-2004, 04:24 PM
zieg96 is starting off with a positive reputation.
I took it out and made a plate to cover the holes. Manual worked until I had the money for a new one. Mine actually rusted through.
__________________
In search of a 1978 F-150 Club cab short bed.
Dealing on a 1979 F-150 Indy Pace truck
  #12 (permalink)
Old 06-21-2004, 07:35 PM
So it shouldn't be too involved to dig into this? And what about the two different boosters in my manual? napa only lists one.
__________________
First On Race Day
  #13 (permalink)
Old 06-21-2004, 08:12 PM
I am pretty sure they both will work. The newer one is smaller in size but it will bolt up.
__________________
  #14 (permalink)
Old 06-21-2004, 08:51 PM
82F100SWB's Avatar
Your manual likley also shows the Dual diaghphram unit found on the F250HD and 350.
__________________
  #15 (permalink)
Old 06-21-2004, 10:35 PM
Yep, just looked at my manual more carefully, the single style is 150-250 and the other one is for 250HD and 350, or something like that. Anyway, only one for my truck, no question there.
Napa lists just the booster for $81 but I know I can get one cheaper. I'll try to bang that out next weekend.
I see there are lots of adjustments, but I guess I shouldn't have to mess with them just changing the booster.
Thanks guys.
__________________
First On Race Day
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
