2004 6.0 fuel filter change - Ford Truck Enthusiasts Forums
Old 06-20-2004, 11:41 AM
alperez alperez is offline
alperez is starting off with a positive reputation.
Question 2004 6.0 fuel filter change
I changed my fuel filter and the water separator light came on. What do I do?
Old 06-20-2004, 12:44 PM
SBV45's Avatar
SBV45 SBV45 is offline
SBV45 is gaining momentum as a positive member of FTE.
Did you drain the water/fuel separator when you changed the filter? Try draining it again. Should let it run for about 25 seconds.
Old 06-20-2004, 12:52 PM
How do I drain it? I assume it is the allen bolt on the bottom? Do I need to have the eginition to on?
Old 06-20-2004, 03:10 PM
SBV45's Avatar
You need a 6mm hex key. Get a empty 3 liter soft drin bottle and cut the top off to have something to drain it in. Get underneath your truck, with the engine off. With one hand, hold the container under the drain plug. With the other hand, reaching from the top of the HFCM, unscrew the plug using the hex key. It is slow going. If you do it that way it will keep diesel fuel from running down your arm. Let it drain for 25 seconds then put the plug back in. You don't have to tighten it too much, just real snug. Let us know how it goes.
Check your Owners Guide Diesel Supplement. The procedure is in there with a diagram, etc.
Old 06-20-2004, 03:59 PM
kw5413's Avatar
kw5413 kw5413 is offline
kw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputationkw5413 has a superb reputation
alperez: How many miles an your vehicle?
Never drained water but now changing fuel filter?
Wouldn't / couldn't not draining water cause premature failure of fuel filters or worse?
Old 06-20-2004, 08:38 PM
SBV45's Avatar
You said fuel filter. As in singular (one). It has two. One on the engine and one on the frame under the drivers door. That is where the fuel/water separator is located. Did you change both. Like kw5413 asks, "how many miles on your truck"? Fuel filters should be changed at 15,000 for normal service.
Old 06-20-2004, 09:16 PM
Kaloha Kaloha is offline
Kaloha is starting off with a positive reputation.
when you buy a fuel filter from ford you get both and a set of instuctions on how to do the change...they provide that because some people where putting the fuel filter where the oil filter goes ,that what the parts person told me....so if you got the filters from ford you should of been provided the install instructions and change them both out every 15000
Old 06-21-2004, 08:28 PM
My truck has 16k and I changed both filters and let it drain for 25 seconds. The light only comes on when I start it and not when it is running? Should I drain it again?
Old 06-21-2004, 09:21 PM
SBV45's Avatar
no, it should come on when you first start up for a few seconds. That is the computer going through tests. If it is off when the engine is running after that, it should be ok! It is only if the water in fuel light comes on and stays on. Sounds like you did ok.
Old 06-21-2004, 09:50 PM
Thank you all very much.
Filter change brother steve 6.7L Power Stroke Diesel 15 10-29-2015 03:24 PM
Metal Shavings in Fuel Filter? Dustball8504 6.0L Power Stroke Diesel 17 09-02-2015 06:58 AM
Water in Fuel Chapabel 1999 to 2016 Super Duty 8 07-15-2015 05:06 PM
7.3 Fule Filter 1L243 1999 - 2003 7.3L Power Stroke Diesel 14 06-13-2015 09:50 AM
Help with Fuel Filter Change Soko179 2004 - 2008 F150 3 05-22-2014 10:56 PM
Tags
2004, 60, 60l, change, diesel, f250, f250sd, filter, filters, ford, fuel, hard, liter, location, picture
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
