351M oil capacity - Ford Truck Enthusiasts Forums
351M oil capacity
Old 06-19-2004, 08:08 PM
rmalottwtes30's Avatar
rmalottwtes30 rmalottwtes30 is offline
rmalottwtes30 is gaining momentum as a positive member of FTE.
351M oil capacity
I have a351 modified in my truck, there is no dipstick the guy before me temperarly plugged it up, so does anyone know where i can find one, also how much oil does it hold, i dont want to put to much in it before i get the dipstick
Old 06-19-2004, 11:37 PM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Tell us about your truck. Is it a 74 dumptruck, ranchero, 4wd or what???
Old 06-20-2004, 03:18 PM
77f2504by4's Avatar
77f2504by4 77f2504by4 is offline
77f2504by4 is gaining momentum as a positive member of FTE.
ford still makes dipsticks for these motors. also our sponsor bronco gaveyard has them.
Old 06-20-2004, 09:35 PM
its the not the motor thats suppost to be in the truck, its a 1980 150 4x4 so all i need to do is contact a ford dealer
Old 06-21-2004, 10:45 AM
77f2504by4's Avatar
i belive the oil capacity is 6 quarts. thats what my truck takes. and if its a 4x4 you have it in, then it has the rear sump oil pan so id assume that the capacity is the same.
Help: 2003 Ford Explorer Dipstick Oil Amount? cocksy Explorer, Sport Trac, Mountaineer & Aviator 7 12-27-2014 10:48 AM
milky white stuff monkey jason 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 01-24-2014 06:38 PM
351W Dipstick Tube cgiles85 1987 - 1996 F150 & Larger F-Series Trucks 6 09-20-2013 08:07 PM
Replacing Oil Dipstick Tube LARIAT 85 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 04-30-2010 11:37 AM
How many quarts oil for a 5.0 EFI ronjon851 1978 - 1996 Big Bronco 3 03-16-2003 08:46 AM
Tags
1977, 1978, 351, 351m, 4wd, 4x4, 78, bronco, capacity, engine, ford, modified, oil, quarts, ranchero
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
