I have a 1988 manual 4x4 and I have a problem with the speakers. I can't get the screws out of the dash around the speakers. They aren't stripped but they are getting there. Nothing seems to work. Any tips would be appreciated.
i used a pair of visegrips with a screw bit in it to get the screws out of mine ...especially the ones in the front closer to the windshield. got those tight screws out fine like that...just a suggestion. post a reply if it works, if you try it.
You can buy a little ratchet drive from Sears that has forward and reverse that holds the 1/4 drive bits. It also has a thumb turn. Fits perfect and works great on speaker windshields of Fords.
