Windshield Wipers stopped working
Old 06-17-2004, 08:17 PM
1998 Ford EB Expedit's Avatar
1998 Ford EB Expedit is offline
In my 1998 Ford Eddie Bauer Expedition...the windshield wipers stopped working while driving in the rain...the A/C stopped blowing cold air at the same time...I have replaced the small fuses but nothing has changed...not sure about the A/C to do either...advice needed on next steps.
Old 06-18-2004, 09:03 PM
OK...I have determined that the switch is working by hearing and feeling that the relays are "clicking", the fuses are fine as well as having volt meter check each one and I have 12 Volts on the wiring harness that is input into the front windshield wiper motor...but before I replace this motor...I still cannot figure out why the rear windshield wiper does not work either...is there some linkage between front and rear wiper wiring?
Old 06-19-2004, 11:42 AM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,678 Likes on 1,356 Posts
Can you check for 12 volts on the fuses? If you have no voltage at the fuses, then there may be a fusible link burnt out over at the starter relay. These links do feed mulitple circuits, so that could explain the other stuff not working.
grandin
1997-2006 Expedition & Navigator
02-24-2015 10:40 PM
Bodger
Electrical Systems/Wiring
11-08-2012 06:48 PM
cleaningbug94
13
10-18-2010 03:13 AM
Larry85355
07-03-2009 01:49 PM
ExplorerRon
07-19-2004 09:27 AM
Quick Reply: Windshield Wipers stopped working
