Windshield Wipers stopped working - Ford Truck Enthusiasts Forums
Old 06-17-2004, 09:17 PM
1998 Ford EB Expedit 1998 Ford EB Expedit is offline
1998 Ford EB Expedit is starting off with a positive reputation.
In my 1998 Ford Eddie Bauer Expedition...the windshield wipers stopped working while driving in the rain...the A/C stopped blowing cold air at the same time...I have replaced the small fuses but nothing has changed...not sure about the A/C to do either...advice needed on next steps.
Old 06-18-2004, 10:03 PM
OK...I have determined that the switch is working by hearing and feeling that the relays are "clicking", the fuses are fine as well as having volt meter check each one and I have 12 Volts on the wiring harness that is input into the front windshield wiper motor...but before I replace this motor...I still cannot figure out why the rear windshield wiper does not work either...is there some linkage between front and rear wiper wiring?
Old 06-19-2004, 12:42 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Can you check for 12 volts on the fuses? If you have no voltage at the fuses, then there may be a fusible link burnt out over at the starter relay. These links do feed mulitple circuits, so that could explain the other stuff not working.
water leaking in dash grandin Expedition & Navigator 11 02-24-2015 11:40 PM
1998 Explorer Sport Wipers dont Work Bodger Electrical Systems/Wiring 2 11-08-2012 07:48 PM
windshield wiper fluid cleaningbug94 Expedition & Navigator 13 10-18-2010 04:13 AM
1998 Expy A/C orifice location? Larry85355 Expedition & Navigator 5 07-03-2009 02:49 PM
Wipers wont shut off ExplorerRon 1973 - 1979 F-100 & Larger F-Series Trucks 4 07-19-2004 10:27 AM
Tags
1998, ford, truck, wipers, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
