Does the air filter gauges work? - Ford Truck Enthusiasts Forums
Old 06-17-2004, 09:01 PM
bkvanbek bkvanbek is offline
bkvanbek is starting off with a positive reputation.
I took my truck in, 13500 miles, to have the computer flashed and to check an oil leak. They said it was because the air filter was clogged and the turbo sucked air through gaskets that resulted in an oil leak. I told them not to put in the filter (for $107) thinking I would go aftermarket.
It does not make sense to me, the filter has a gauge that stays at the highest vacuum. I have the truck back, with the old filter, and the gauge does not show a clog. It did not show a problem when I took it in either.
Can any tell me if the dealer is full of it?
Has anyone heard of the AFE Proguard 7 intake stage 2? It is to be released soon.
Old 06-17-2004, 10:00 PM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is offline
jdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputation
I also question the function of the air filter minder !
I have 29K on mine and have not changed the filter and it hasn't MOVED since I bought it...
course I only know that because I STARED at the stupid thing to try to figure out how are you supposed to read anything as idiotic as that --- then saw that there is an equally idiot light on the dash for the air filter minder and for the water in fuel so I figured I was qualified to watch the idiot lights !
Old 06-17-2004, 10:10 PM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
Where was the oil leak?
Old 06-17-2004, 10:13 PM
donjuanmiguel donjuanmiguel is offline
donjuanmiguel is starting off with a positive reputation.
I don't know how reliable they are. I have read somewhere else that some have had to be replaced. I have had mine since 10/03 and until recently did not move. Now it's move up to the first mark. I don't know if I should be excited about this or nervous. Either way, I ordered a new filter just to be on the safe side. I have noticed a drop in mpg over the last couple of months and have decided to begin replacing things one a time to see if they have an effect on the mpg. I'll begin with the fuel filters tomorrow.
Old 06-17-2004, 10:17 PM
Beachbumcook's Avatar
Beachbumcook Beachbumcook is offline
Got Diesel?
Beachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to all
My diesel tech stayed at a Holiday Inn Express last night..... and he said....
1) Change yur filter at 30,000 miles as mandated in your owners manual.
2) The filter minder only works when the motor is under load... which means more than idle. So, you need to have someone step on the "go pedal" and watch if there is any movement. If so, then a clog is starting. Under idle, not enough vacumm or air intake requirements that would cause the minder gauge to move.
3) This filter is alot better than the 7.3's. Cleans better and allows for better airflow.
Well, that's what he said and I guess if he stayed at a Holiday Inn Express last night that he knows his stuff??
Thanks,
Jeff
Old 06-17-2004, 11:27 PM
FordxFour FordxFour is offline
FordxFour is a splendid one to beholdFordxFour is a splendid one to beholdFordxFour is a splendid one to beholdFordxFour is a splendid one to beholdFordxFour is a splendid one to beholdFordxFour is a splendid one to beholdFordxFour is a splendid one to behold
Beachbumcook, hate to be the bearer of bad news but your tech told you wrong. This is the same meter they've been putting on "Big Rigs" for 20 some years and they don't work like that. If you get in your truck and drive it as you normally would, when the filter starts getting restricted you will be able to tell it even after you park the truck and turn it off. Thats why it has a reset button. Might want to make sure the filter minder is not faulty. Have them on all my diesels, they work great.
Old 06-17-2004, 11:59 PM
Hayapower!'s Avatar
Hayapower! Hayapower! is offline
Hayapower! is starting off with a positive reputation.
The filter minders got a 'bad rap' on the 7.3's.. They didn't work well alot of times because the service techs, or quickie lube stations would break the 'eyes' on the filter box during a change, and the lids would'nt pull down flat, creating a void in the sealing area/lip, and the minder would never rise.. Or the paper thin 'eye' would snap on its own with age.. Air filters are cheaper than engines.. And with the now SO CALLED 'warped look' of the OEM filter unit, I won't be putting much faith in them or the minder.. Hard to beleive that Ford puts such a sub standard filter unit on such an expensive engine.. I'll let my own 'minder' keep a close 'look see'.. And it is true, that the minders will 'pull till full' and stay locked until manually reset..
..........................HP...................... ...........
Old 06-18-2004, 07:30 AM
IB Tim's Avatar
Site Administrator
Quote:
After reading this thread I went out and took min off the truck ........looked and looked, and you are correct. It does seem to be a very simple devise and does not require re-flash to reset the darn thing
Great thread
Old 06-18-2004, 07:46 AM
Tim, It was unclear where they said the oil leak came from. But I believe they meant it leaked form the turbo, the oil that lubs the turbo.
Old 06-18-2004, 07:59 AM
IB Tim's Avatar
Site Administrator
OK that is weird one, do you still have the paper work, the reason I ask this is good info for our readers. If we understand another problem with a clear and easy fix.......GREAT....
Can you trace it back and let us know?
Old 06-18-2004, 11:48 AM
Got Diesel?
I defer to your wisdom and agree that with the "warped" filter housing and the toughness of changing the filter, I to will defer to my own review and not base my changes of the filter on the idiot light.... I mean idiot filter minder.
Thanks for the info and advice.
Jeff
Old 06-18-2004, 11:49 AM
Got Diesel?
Makes sense, forgot about the "reset button" and I will defer to your expereince or insight that they have been used for years.
Thanks,
Jeff
Old 06-18-2004, 12:04 PM
Hayapower!'s Avatar
Quote:
Thanks,
Jeff
The Filter Minders aren't really a bad item.. They work 'very well' in the heavy equipment/trucking industry.. But they're usually 'mated' up to a Donaldson ect. filter housing, that 'clamps' or bolts down tight.. Way better constructed than our plastic unit.. When our equipment is working in 'very' severe dust conditions, they work well as a 'warning' alert for early service, if the equipment/engine isn't due for it's mileage/hourly change.. I just wouldn't put 10-15,000 worth of trust in the 'little helper'
Old 06-18-2004, 11:04 PM
IB Tim's Avatar
Site Administrator
Could it be they are really good for the folks that are in very dusty areas, that would normaly not check under the hood all the time.
We all check more than enough, so it would never work for us.
hard starting, spark knocking, reverse stalling, sometimes rough idling? no ford shop can figure out thechainsawman 1987 - 1996 F150 & Larger F-Series Trucks 10 11-15-2016 09:13 AM
Cycling Oil Pressure '92 5.8 jbsman0048 1978 - 1996 Big Bronco 2 06-02-2015 07:24 PM
No Oil in Filter Housing gmcbride 6.0L Power Stroke Diesel 4 03-23-2015 09:49 PM
Troubleshooting a "low power" condition bismic 6.0L Power Stroke Diesel 10 09-23-2014 08:17 PM
How long can the OEM air filter last? smlford 6.0L Power Stroke Diesel 11 08-07-2011 09:56 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
