bleeding a clutch
Old 06-16-2004, 08:00 PM
pirocat29's Avatar
pirocat29
pirocat29 is offline
bleeding a clutch
I just got done redoing my clutch and i had to pull my trans how do i effeciantly bleed the clutch. I have cracked the bleeder screew more then 20 times and the pedal does not get any stiffer and i have been adding dot 3 fluid. Help me ASAP
Old 06-16-2004, 08:29 PM
golfboy17's Avatar
golfboy17
golfboy17 is offline
Did you replace the slave cylender? These tend to leak once you replace the clutch and you minds well do it when you have the tranny out with the clutch since you need the tranny off to replace the slave cylender..if its leaking you wont have pressure in the clutch
Old 06-19-2004, 01:19 AM
pirocat29's Avatar
pirocat29
i replaced the master and the slave and i still have a soft pedal. The clutch engages almost at the floor but before it engages its pretty much a dead zone.
Old 06-19-2004, 01:26 AM
pirocat29's Avatar
pirocat29
I have one more question i put gear lube in because i know that in GM and Foreign you are sopposed to but when i got my Exploder it had ATF. Since i have been done (1 day) i have been smelling burning gear lube and my trans is getting real hot
Old 06-19-2004, 11:50 AM
mrshorty's Avatar
mrshorty
mrshorty is offline
The Mazda M5OD transmission does indeed require Dexron III/Mercom ATF.
Old 06-20-2004, 07:49 PM
golfboy17's Avatar
golfboy17
when the clutch is replaced its normal to get a burning smell from the vehical unless the smell does not go away then be concerned
Old 06-21-2004, 08:39 AM
99Xplr's Avatar
99Xplr
99Xplr is offline
Since I don't have a 5 speed Explorer I'm just shooting in the dark on this one for you... but I have done some work on other hydraulic clutches.... when you are bleeding the clutch, you really need two people. One person sits in the cab and pumps up the clutch, then holding it to the floor, you crack the bleeder under the hood. Do this a few times and the clutch should firm up. If not, you have other problems.... i.e. a lot of air trapped in the lines.
Old 06-21-2004, 10:49 AM
ranger88a's Avatar
ranger88a
ranger88a is offline
remove the master cyl from the firewall, hold it upside down and have someone crack the bleeder screw loose. Then push the master cyl rod by hand all the way down, tighten bleeder screw, let loose of the master cyl rod, and repeat. All in all it sucks, the master cyl sets uphill if you get what I mean and traps air. It's not easy to get the air out.
89nolaf250
01-31-2010 01:37 PM
fordfinatic
02-07-2009 09:04 AM
keyes
05-07-2008 08:19 PM
srumble
11-17-2007 06:36 PM
JustinGustafson
11-16-2006 01:42 PM
Quick Reply: bleeding a clutch
