I have a 1993 Ford F-150 4x2 5.0-302 with the E4OD Transmission. Does anyone know where i can find that transmission. This would be helpful information.
where in this fine state are you located, are u in the cities, north,south? i would say viking will be able to accomodate you and get you a warranty, johns, so so, but i think a few in st paul over off sycamore, had 1 or two of that era, and off jefferson around 35e n marylnd is another one that would have some newer stuff. those would be my guesses, but something that new should be plentiful. have you thought about going with a c6? much cheaper and user friendly. swaps arent too bad if its already out.
Thanks for the input, I will check with those. Iam located in Isanti, MN, But all the local parts stores say that those E4OD Transmissions are hard to find.
viking should be able to take care of you but they tend to be more expensive and about 1 1/2 hours away from you in farmington. but for my hard to find stuff, they usually found it. i always thought of them as the quality junk yard,
i know there are some new stuff dealers in anoka, and aaa some times has it, and i dont think french lake in annandale has anything that new soo much, they might be in your neck of the woods.
