How to: remote door locks - Ford Truck Enthusiasts Forums
Old 06-15-2004, 07:00 PM
buckeyebronco's Avatar
buckeyebronco buckeyebronco is offline
buckeyebronco is starting off with a positive reputation.
Trying to put in a Rattler Car Alarm with Remote Door Locks and Can't figure out how to wire the door locks so the remote works. another problem I am having is how to hook up the remote kill, if the vehical is started without the key it will shut off. Can any of you Bronco guinesses help me out.
Old 06-15-2004, 11:10 PM
andym's Avatar
andym andym is online now
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
Did someone say Guinness?
Old 06-15-2004, 11:28 PM
Jdenninger's Avatar
Jdenninger Jdenninger is offline
Jdenninger is starting off with a positive reputation.
first off, what year? the starter kill: you need to cut the wire for the starter under the dash and put them to the normally closed of a relay. the positive of the relay coil goes to the alarm, ground to ground. when the alarm is activated, the realy will engage and kill the ability to start the truck with a key. the door lock may require a 5-wire relay harness. what does the alarm have for outputs to door locks?
Old 06-16-2004, 08:45 AM
its a 90 and the alarm has about ten options for hooking up the door locks. I tried hooking them up on the drivers side but they didn't work. is there a reason that I would have to hook them up to the passenger side locks?
Old 06-16-2004, 09:57 AM
Jdenninger's Avatar
how many wires on the alarm for the door locks?
Old 06-16-2004, 12:00 PM
BillyBob69's Avatar
BillyBob69 BillyBob69 is offline
BillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to all
You have the 5 wire door lock switches. The reason you have to put em on the passenger side is because that is the master for the doors locks. You will need to get 2 door lock relays...about $5 bucks each. Do a search on the net for FORD KEYLESS ENTRY or just KEYLESS ENTRY. You will find wiring diagrams that will help you specifically for the bronco. I would send you the diagrams I paid for when I did mine but its been about a year and I couldn't find em if my life depended on it.
You will see that you have to cut the LOCK and the UNLOCK wire completely, then wire in the relays. When I did mine, I cut them inside the door panel and added the connectors with the male and female opposite of each other. That way if there ever is a problem, I can pop the panel and reconnect the wires the way they were.
Also I mounted the relays behind the passenger side kick panel for easy access and routed the wiring through the boot from the door to the fender using a wire hanger to fish the wires through.
If you cant find the diagrams... Or need any other help, email me through my profile and I will see if I can locate something that will help. I may have something at home.
Old 06-16-2004, 12:20 PM
BillyBob69's Avatar
Check out my Gallery. I have a pic in there under MISC. It is the same wiring I used for my truck.
http://www.ford-trucks.com/user_gall...=46212&width=0
Remote Door locks Bear 45/70 1997 - 2003 F150 15 02-13-2012 05:00 PM
Remote start issues turbodog 2007 - 2014 Expedition & Navigator 3 04-27-2010 05:14 PM
2001 F250 - Keyless Entry Remote Setup lalevant 1999 to 2016 Super Duty 4 10-08-2008 06:47 PM
Remote fob for 2001 F250 darmar43 1999 to 2016 Super Duty 5 05-24-2008 01:27 PM
Remote door locks Vankaye 1999 to 2016 Super Duty 4 12-31-2004 06:19 PM
Tags
90, alarm, bronco, car, cut, door, lock, locks, minnasota, rattler, relay, remote, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
