Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-15-2004, 04:26 PM
bigdieseldav bigdieseldav is offline
Garage is empty, add now
bigdieseldav is starting off with a positive reputation.
Propane is Awesome!!
I just wanted to say thanks to everyone especially Mr. Quadzilla for all the information on propane I have been seeking over the last few months on this site and the last year elsewhere. It was a great help.
Now on to the fun part. Propane is awesome. My truck ran like a monkey on fire before, but now it is unreal. An objective opinion after playing for a few days is that it did little that I could notice from stoplight to stoplight. A lot of that had to do with the fact that I don't like giving my truck alot of hell while running through gears. Not on the other hand on the highway, it was unreal how much power the stuff hand over to you. Even with light accelerator application, its like you start taking off. On an assertet application, you literally have to back out to keep from getting into the high 90's or 100's. I am now a bonafied Propane Advocate. Set up and used correctly of course. The fun part is that I am still not finished fine tuning the Powershot system I am using. Its hard to believe it might unleash more power... Anyway, thanks again to everyone who I drew information from in the process.
__________________
2005 6.0 PSD, auto, lariat longbed crewcab FX4 lifted 4 inches. ARP headstuds, black onyx headgaskets, 4 inch turbo back kitty and muffler delete, egr delete, smoke switch, high idle mod... superchips flashpaq with powershot 2000 propane injection system.
  #2 (permalink)
Old 06-15-2004, 11:23 PM
WeWeld WeWeld is offline
WeWeld is starting off with a positive reputation.
Have FUN but don't get to carried away remember the warnings.
Your hooked NOW
GENE
__________________
99 F450 CC, AT, XLT LB
List Mod's in Gallery
Builder and Driver of Stroked Lightning 11.519 @ 119.26 mph
CoBuilder of De Ranged
  #3 (permalink)
Old 06-16-2004, 04:40 AM
Quadzilla's Avatar
Quadzilla Quadzilla is offline
Quadzilla is gaining momentum as a positive member of FTE.Quadzilla is gaining momentum as a positive member of FTE.
Dave- You've got my email address. If I can be of help in dialing it in, let me know.
__________________
When you're walking away from your truck, do you turn around just to look at it? Yeah, so do I. ☺
'13 F-250 Platinum CC SB 4X4 Powerstroke.
  #4 (permalink)
Old 06-18-2004, 12:50 PM
SoundBuys SoundBuys is offline
SoundBuys is starting off with a positive reputation.
what system did you go with? I have been looking at systems for my 00 PSD also
  #5 (permalink)
Old 06-18-2004, 03:38 PM
i got the powershot2000 system. I researched for about a year beforehand, and it seemed the simplest, safest, and didn't require an engine coolant vaporizor....... I can't say that it is best system, but definately the safest and most user friendly....I like how the introduction of the gas is proportioned instead of "dumping" propane at a certain boost. Its really smooth. The only time you will feel a jolt of power is if you are above the preset boost level with the system off, and then turn it on, then it kicks in gear pretty hard.. Otherwise it is a powerful yet smooth difference. Now that i'm pretty close to finished with all my toys on the truck, I am starting to create my gallery, I will post pictures of my beast very soon......
__________________
  #6 (permalink)
Old 06-18-2004, 04:16 PM
Kevin24 Kevin24 is offline
Kevin24 is starting off with a positive reputation.
what do you think the MPG benie will me in normal ops if any
__________________
2003 SD350LB lariet
7.3 psd Sonic Blue/Grey
  #7 (permalink)
Old 06-18-2004, 08:49 PM
I couldn't tell you, I've only filled up once since i installed the kit, and the way i've been driving wouldn't indicate a positive result. I'm going to make a 500mi trip next weekend where I plan to use it moderately on the highway, and I'll let you know.
__________________
  #8 (permalink)
Old 06-19-2004, 05:38 AM
Quadzilla's Avatar
If you set the propane to come on moderately on the freeway, you'd reach maximum mpg improvement. If you "wick it up" and have the propane come on quicker/stronger, you'll see a larger improvement in fuel consumption, but will use a lot more propane in the process, which offsets the gain in diesel usage. When the system is set properly, many guys report a 2-3mpg improvement.
__________________
  #9 (permalink)
Old 06-22-2004, 08:32 PM
powershotone powershotone is offline
powershotone is starting off with a positive reputation.
I see right about 2-3 mpg with a 5psi start time and a heavy right foot
  #10 (permalink)
Old 06-22-2004, 10:10 PM
rmilchman rmilchman is offline
rmilchman is starting off with a positive reputation.
Doesn't seem to me that 2-3 MPG would cover the cost of propane neverless the kit cost. But it sure does sound like fun...
__________________
2002 F-350 4X4 CC PSD. straight pipe, k&n air box, tuner, 203 thermostat, mag-hytek tranny pan, tranny springs and valve, ranchhand bumper, air horns
  #11 (permalink)
Old 06-23-2004, 04:31 AM
Quadzilla's Avatar
I agree. If you're thinking of adding propane merely to save fuel, you'd have to drive for a long time to recoup the savings, since the propane fuel itself is an additional expense. I did it for the power increase, and the improvement in the overall driveability of the truck.
If that's your rationale, you won't be dissappointed.
__________________
  #12 (permalink)
Old 06-29-2004, 12:34 PM
Well, ya, the power is great fun too
  #13 (permalink)
Old 06-29-2004, 09:05 PM
8mpg 8mpg is offline
8mpg is starting off with a positive reputation.
can you send me some info on the whole propane thing??
  #14 (permalink)
Old 07-02-2004, 11:46 AM
You want to know about the basics??
  #15 (permalink)
Old 07-02-2004, 01:50 PM
yeah...if you could send me some info
Tags
adjustments, build, diesel, injection, propane, trickle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
