1950 Ford floor board Sheet metal - Ford Truck Enthusiasts Forums
Old 06-15-2004, 07:24 AM
Christopher2's Avatar
Christopher2 Christopher2 is offline
Christopher2 is starting off with a positive reputation.
What is a good source for sheet metal for a floor? The entire floor where your feet go. The seat seems solid enough. I am think of just buying metal fleet galvanzied metal and welding it in. Cover it with some carpeting and call it done.
Old 06-15-2004, 05:46 PM
Schoonie48F2's Avatar
Schoonie48F2 Schoonie48F2 is offline
Schoonie48F2 is starting off with a positive reputation.
Try the online store, or Macs auto parts. They should both have the floor pans.
Old 06-15-2004, 05:59 PM
The online store does not go back that far. I will try Macs
Old 06-15-2004, 08:17 PM
Macs has them, the problem is they want more for the sheet metal than I paid for the truck $500.00 shipped.
Old 06-15-2004, 08:51 PM
dmptrkr dmptrkr is offline
dmptrkr is starting off with a positive reputation.
Both these places list floor pans:
Obsolete Ford Parts
C&C Early Ford Parts
About $125 each side. Shipping is probably the killer. I notice you are in Minn. If you are not far from St. Paul "Back to the 50's" Swap meet is this weekend. If you can find a vendor that has them and will be going to the meet and hasn't left yet, you can probably get free shipping.
There is a tech article on this site about making your own replacements.
Craig 50F5
Old 06-16-2004, 08:29 AM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
Have you tried Northern Classic Trucks:
The have the floor in two halves.
or EMS:
EMS Sheet metal
They had a one piece floor panel the goes from side to side and from the front seat mount to the toe board, up to where the floor meets the slanted sheet metal under the pedals. I didn't see it listed on their website, you'll have to call them to make sure they still make it.
BTW, if you go with the galvanized metal idea, make sure you use good ventilation and breathing protection. Welding galvanized metal really gives off noxious fumes, it will make you sick if you're not careful. I would go with regular mild steel and then apply a good epoxy primer and paint.
Old 06-16-2004, 09:13 AM
Scott123 Scott123 is offline
Scott123 is starting off with a positive reputation.
I'd recommend Northern Classic Trucks too, their floorboards were much cheaper than other companies at $75 each side. They fit well too. I have pictures of them installed on my gallery.
Scott
Old 06-16-2004, 02:58 PM
jniolon's Avatar
jniolon jniolon is offline
jniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud of
Christopher,
I didn't see the reasoning to pay so much for 'custom' formed floor panels... I just bought some 14 ga cold rolled sheet (actually I got it at work) and cut out the toeboard and back to the seat... welded in the patch piece and was done... I plan to undercoat the bottom, seam seal the joints and carpet the top... who'll know ??? still have to build the hump...but you can see what I've done...
check with a local steel supplier or fab shop... you might find a piece large enough in their drop pile... 2' x 5' would do the lower floor and another to do the toe board... pay attention to bracing the cab before you start torching...
here's the article on the install...
http://www.clubfte.com/users/jniolon...oorboards.html
hope it helps
later
john
Old 06-16-2004, 08:51 PM
I like the home made floor board idea. i think I can get the metal fairly cheap. I will have to price that versus a factory made one. The F-3 needs teh floor and the toe boards. The fenders surprising have less rust then my 1977 4x4. I am actually going to drive the truck and work on it. It will be as econd vehicle and a pass time that I enjoy.
Old 06-16-2004, 10:32 PM
OilLeaks's Avatar
OilLeaks OilLeaks is offline
OilLeaks is starting off with a positive reputation.
I haven't had to deal with floor pans on my truck but on my last two MGBs I had to replace the floor pans and made my own from 14 gauge galvanized steel as John did. Worked just fine and I did both cars and have a big piece of steel left over for a fraction of what one formed pan would have cost. Yes it was more trouble and of course it's not any good if you're concerned with a true restoration - but if functional preservation is your goal and you're budget minded it's the only way to go. Do be careful if you use galvanized metal because - as was already noted - if you breath the fumes from the galvanizing material it will make you very sick indeed. Grind or sand the galvanized area back at least a 1/2 inch where you intend to weld and then be sure that you have a well ventilated area to work in or wear an appropriate respirator or both. It's not something to play around with.
Good luck!
Leaks
66 f250 metal thickness brianc613 1961 - 1966 F-100 & Larger F-Series Trucks 5 10-18-2016 10:21 PM
Cab Sheet Metal? LesPaul 1973 - 1979 F-100 & Larger F-Series Trucks 14 08-12-2015 11:05 PM
78 f series sheet metal ford_0004 1973 - 1979 F-100 & Larger F-Series Trucks 0 12-16-2014 07:35 AM
What Gauge Sheet Metal fo Floor Boards Ripcity 1973 - 1979 F-100 & Larger F-Series Trucks 3 10-12-2013 10:45 AM
Cheap sheet metal brake jrockdiddy 1948 - 1956 F1, F100 & Larger F-Series Trucks 22 12-16-2012 10:30 AM
Tags
1950, boards, floor, ford, metal, replace, replacing, sheet, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
