What oil to use in F-150 2004 - Ford Truck Enthusiasts Forums
Old 06-15-2004, 06:58 AM
Wolfdog Wolfdog is offline
Wolfdog is starting off with a positive reputation.
Question What oil to use in F-150 2004
I live in Switzerland and it seems that 5W-20 oil is hard to get over here. My Ford garage recommends to use 5W-30 with my new Lariat.
One oil importer also said that in Europe the speeds are usually higher (I guess referred to Germans highways -- NO speed limit) so I should use a higher viscosity oil like 5W-30 or 40.
Although I don't drive usually very fast about 50 to max .70 milesph on the highways. I think my driving style is more "stop and go and stop.."
Can anyone help?
Old 06-15-2004, 09:29 AM
Dr No Dr No is offline
Dr No is starting off with a positive reputation.
I would use the 5w30 if it meets the ford spect number in your owners manual.There is not much difference between 5w20 and 5w30.
Mike
Old 06-15-2004, 10:24 AM
chopperdude chopperdude is offline
chopperdude is starting off with a positive reputation.
I'm gonna switch to Mobil 1 Syn 5-30 at about 1200 miles.
Does not void the warranty either.
Old 06-15-2004, 11:02 AM
Sidelt Sidelt is offline
Sidelt is starting off with a positive reputation.
I will also be changing to Mobil One Synthetic 5w-30. Only I am waiting until the first oil change at 3,000. I read somewhere that it is good to use conventional oil for the first 3,000 to let the gaskets seal and such...
Old 06-15-2004, 02:57 PM
khendrix khendrix is offline
khendrix is starting off with a positive reputation.
I switched to mobil 1 5w-30 at 3000 miles. No problems at all. The engine runs just a hair cooler and even runs about 250 RMP lower believe it or not. Before you change oil, look closely a all your gagues, then look again after oil change.
Old 06-15-2004, 06:46 PM
ctfordguy ctfordguy is offline
ctfordguy is starting off with a positive reputation.
Oil viscosity can not affect engine RPMs. Only gearing and tire size will affect engine RPMs.
Old 06-15-2004, 07:28 PM
deceptikon deceptikon is offline
deceptikon is starting off with a positive reputation.
I just changed mine to Mobile 1 0w-20. It meets Fords 5w-20 requirements. I must say..that is some thin oil!!!!
Old 06-16-2004, 01:31 PM
ksutty ksutty is offline
ksutty is starting off with a positive reputation.
I use Royal Purple Synthetic only. I don't know if you can get it over there but it's one of the best. I live in Florida so I use 10W30 because of the weather.
1964 F100 "Custom-Cab" top speed swiss-cruiser 1961 - 1966 F-100 & Larger F-Series Trucks 11 12-17-2014 10:40 AM
New Member Switzerland Lewis1960 New Member Introductions 4 11-05-2014 03:13 PM
Centane numbers and ratings jayman2 6.7L Power Stroke Diesel 15 01-31-2011 11:28 PM
Thermostat Type ??? (2 completely different ones ) broncoray Bronco II 1 12-18-2003 08:10 AM
Tags
04, 2004, 2008, change, changing, dose, f150, ford, hold, oil, recommendation, synthetic, truck, type, viscosity
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
