t86e transmission
Jef,
I posted another reply under another topic. Just to make sure you get it I'll post it again here. Transmission Exchange Company ( http://www.txchange.com
) sells cluster gears. I recently inquired about parts for the T86 and they do have them. The custor gear was $144. A rebuilt OD transmission was $816 + $200 core. It wasn't stated in the e-mail reply I received from them, but I assume that for the trans only. Not trans + OD.
Lance
Lance
If you're looking for a NOS Ford one, I looked them up and located one of each as you don't list which engine you have.
B7C 7113-A is for 223 engine Wesley Obs. Liberty, Ky. 1-8606--787-5293 Qty 2
B7TZ 7113-B is for 292 Greene Sales, Cinci, Oh. 1-800-543-4959 Qty 1
You can call them up and see if they still have them.
Hope this helps,
Barry
50 F-1
Hope this helps,
Barry
50 F-1
The T90 used in Jeeps is almost exactly identical to the T86. Almost all internal
parts interchange. As well as the top shifter and the case. If a Ford part vendor
does not have what you need, check with a Jeep vendor and use the T90 name
The only difference internally between the two is that the T90 has straight cut
first/reverse gears and the T86 are helically cut.
sep3bub
06-16-2015 01:54 PM
