Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Supercharger, Turbocharger, Nitrous Oxide and Water/Methanol Injection
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #106 (permalink)
Old 03-08-2007, 02:02 PM
Bruce R Leech Bruce R Leech is offline
Bruce R Leech is starting off with a positive reputation.
I will be waiting to here more about this project. also would like to see some photos.
Bruce
  #107 (permalink)
Old 03-16-2007, 08:02 PM
Mtthwvn73's Avatar
Mtthwvn73 Mtthwvn73 is offline
Mtthwvn73 is starting off with a positive reputation.
Same here...love to see this things finished and back in the truck.
  #108 (permalink)
Old 04-02-2007, 12:47 AM
84Maztang 84Maztang is offline
84Maztang is starting off with a positive reputation.
id like to see more on this engine also!
__________________
1987 F-150 4x4 302...slightly modified for Cyote Hunting! He! He! he!
1983 F-100 2wd 4 spd 300-6 Baby blue, baby Yeah!
84 Mazda Rx7- 84 EFI 5.0 AOD 4.10 gears Posi rearend plus additional mods!
Lots of other cars but no other Fords
  #109 (permalink)
Old 04-03-2007, 09:34 AM
cleatus12r's Avatar
cleatus12r cleatus12r is offline
cleatus12r has a great reputation on FTE. cleatus12r has a great reputation on FTE. cleatus12r has a great reputation on FTE. cleatus12r has a great reputation on FTE. cleatus12r has a great reputation on FTE.
He's got the parts for the rebuild...just waiting on time to put it together.
__________________
Cody
  #110 (permalink)
Old 04-10-2007, 09:13 AM
cleatus12r's Avatar
Hopefully he'll chime in shortly. He's got it running again. Put about 450 miles on it so far.
__________________
Cody
  #111 (permalink)
Old 04-25-2007, 10:55 AM
turbo300six turbo300six is offline
turbo300six is starting off with a positive reputation.
Well it's all back together again with some new wiseco slugs and total seal gapless rings. I wasn't able to put the cam in that I wanted. I would have had to get more machine work done on the head to fit the cam and I ran out of time on the assembly and install. (had to get it running in 4 days) I've got the boost sitting at a nice 8lbs. and getting about 15 mpg on the highway. So the next plan when I get more time and money will be to throw the cam at it and see how it responds, but for now I will enjoy my reliable 8lbs. and good mileage. here are some pics before the head went on.http://www.ford-trucks.com/user_gall...id=149357&.jpg
http://www.ford-trucks.com/user_gall...id=149358&.jpg
http://www.ford-trucks.com/user_gall...id=149359&.jpg
  #112 (permalink)
Old 04-25-2007, 11:31 AM
99F150 99F150 is offline
99F150 is starting off with a positive reputation.
Looks good. Are you running an intercooler? Is this cam stock?
Dan
  #113 (permalink)
Old 04-25-2007, 03:19 PM
xtrford xtrford is offline
xtrford is gaining momentum as a positive member of FTE.
I just love those six big cylinders inline, glad evrything is working for ya!
  #114 (permalink)
Old 04-27-2007, 09:07 AM
SR_Crewchief SR_Crewchief is offline
SR_Crewchief is starting off with a positive reputation.
Eric, looks good. Glad to see that you've gotten that beast up and running again.
Are you still planning on using the Crane 503905?
I presume that the head work you mention is for dual valve springs.
The pistons look good. what size dish do they have? I presume that you left CR around 8.8:1.
Still using your custom ecu? Any changes to coil or distributor?
Still running 19# injectors or have you moved to something bigger?
Are you controlling fueling and timing with your ecu or seperate controllers?
__________________
1988 F150 std cab LB 4x2 300/4.9l M5OD 3.08's 288,000+ original miles.
  #115 (permalink)
Old 05-31-2007, 02:05 PM
okwaho1650's Avatar
okwaho1650 okwaho1650 is online now
okwaho1650 is starting off with a positive reputation.
all i have to say is wow how good is it in towing
__________________
The Bounty Hunter Outrider Joe
1977 F-350 Ranger XLT
Crewcab ShortBed Dually
  #116 (permalink)
Old 06-11-2007, 10:50 PM
eriksf250 eriksf250 is offline
eriksf250 is starting off with a positive reputation.
hey turbo300six, you should check out this site http://www.araoengineering.com/, they make 32 valve heads for small and big block fords, you should see if they can make a 24valve head for your 300. that would throw some incredible numbers at you and still retain your stock bolt ons.
  #117 (permalink)
Old 06-17-2007, 02:18 PM
Towmanjbo's Avatar
Towmanjbo Towmanjbo is offline
Towmanjbo is gaining momentum as a positive member of FTE.
I was looking at your gallery , cool build !! The air box has one outlet then Ford split it into two I was wondering why you didn't just start at the air box rather than making another "y" pipe. It would clean up the appearance if anything. Might help with the air flow. Maybe put a Tornado thing in as well.
__________________
Justin
1996 F250 XLT Xcab 4x4 7.3 E4OD
1993 Bronco XLT 4" lift w/ 33"s 5.8 E4OD (sold)
1992 F150 Custom/XLT 4x4 4.9 E4OD
1983 F150 Custom/XLT 4x2 4.9 C6
  #118 (permalink)
Old 07-04-2007, 11:55 PM
Flat's Avatar
Flat Flat is offline
Flat is starting off with a positive reputation.
Awesome man . Can you say sleeper. Thats different and different is good
  #119 (permalink)
Old 07-13-2007, 04:50 PM
myakkacracka myakkacracka is offline
myakkacracka is starting off with a positive reputation.
hey i just wanted to say im lovin the build that you are doing. I am currently putting a garret T3T4 on my 96 5.0 f150 I got just about all the same things that you have been doing with the injectors and exhaust work but im using a MSD ingition retarder. I didnt read everything so some one may have asked you this but I have been wondering about the vacuum no begin right to run my A/C and brake stuff did you do anything with that or does it all work out
  #120 (permalink)
Old 07-19-2007, 04:40 PM
DOHC330MustangGT's Avatar
DOHC330MustangGT DOHC330MustangGT is offline
DOHC330MustangGT is starting off with a positive reputation.
Subscribing....
Awesome project!
__________________
1987 F250 Regular Cab long Bed XLT Lariat w/ 230k miles.
EFI 302, Dual tanks, NP435 trans, and 10.25 axel with 3:73 gears.
Undergoing a 5.0L HO longblock swap!
1997 Mustang GT
Deep Violet Clearcoat Metallic
4R70W to TR3550 swap
04 aluminum block PI 4.6L SOHC swapped
Tuned by Joe at Dynospeed
Tags
250 , 300 , dimensions , f150 , ford , hard , inline , kits , pulses , relocation , starts , tfi , throttle , turbo , www
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
