why aren't you wanting to run an intercooler? if you did that your detonation problem wouldn't be near as bad and the water would help that much more. the kit looks pretty solid. is there a problem with relocating the filter on those trucks?
Well to answer some questions for everyone. Here is the summary of the whole project.
1989 4x4 F150
engine: 300-6 bone stock and 140K miles to top it off.
clutch: 10 inch disc...Its time for an 11" this one slips under boost
transmision: Borg Warner T-18 4spd.
transfercase Borg Warner 1356
gears 3.54:1
Turbo: Warner-Ishi from 6.5 GM diesel
Piping: custom fabbed by myself
Target boost pressure: 10PSI have run as high as 15 PSI.
Fuel management: Megasquirt and spark using stock distributor and TFI, Dynojet wide band air fuel guage controlling fuel ratios
Wiring harness: OEM..removed 60pin EEC-IV header connector from scrap ECU and built a "plug and play" wiring harness adapter.
Fuel economy: 14.2 MPG HWY when I'm not hogging on it. I expect to get 15-17 range when completely dialed in.
Why?: 1. I want to prove that economy and power are acheivable
2. I'm tired of the common small block, big block game everyone and their cousin has run and currently runs.
3. The 300-I6 was used as an industrial engine on used equipment and is built very well with its 7 main bearings and is about perfect for this kind of application.
Current miles on projet: 14K abusive miles, and now that I have everything dialed in much better I haven't really seen any adverse effects on the engine.
1989 4x4 F150
gears 3.54:1
My buddy had an 88 F150 similar to your truck, but running 3.08 rears w/ bigger tires. When he "lost" the truck, he had at least 220,000 on it (didn't blow....lost it as colateral to a debt). Mains were worn, since you could see the crank "creep" forward/back a bit. BUT it didn't burn oil.... he would have loved to see his I6 turbo-ed.
I agree w/ everything you said. The 300-I6 was used as the base engine on the 1960's C-series cab over Ford truck and others. It has enough grunt to move a GVW 26K, then it should be fine in a reg. pickup. Everyone is doing V8's. Nothing 'new' there, but going "back" to suping up I6's, that's different. Just about everyone asks me "Why?" and I say, "Why not." They keep saying get a car w/ a V8 and I say, why.... everyone has/does that.
Hey, what kind of enigne do the big diesels run? INLINE 6's!
I plan to do my own turbo I6 300. But mine is an older 83 F150, so I don't have any computer to deal with. I felt uncomfortable w/ running the motor it has currently (stock original w/ 145,000 miles....who knows how many hours....idels a lot....FARM RIG....has enough blow by that it pushes my oil stick out....).... so I picked up a I6 rebuilt off of Ebay for just under $600.
I'm still in planning stage for my turbo project. I plan to get the engine assembled and ready to drop in. Hopefully I can fab the turbo mount w/out it having to be inside the engine bay....(fingers crossed). Planning to use a 4 barrel intake topped w/ a 2 barrel carb (progressive type if I recall what my parts store guy said). Exhaust, use later model I6 heads (two peice, front and rear- like on your 89) and then plumb them together and mount turbo just under (in theory). Thought about a blow through, but leaning toward the other method (forgot name). I'm sort of worried about the vaccume affects, as it has a C6 tranny. Thought about running an intercooler too.... but plumbing would be a nightmare I think. Also thought of running a high volume oil pump, engine oil cooler & temp guage. If they make a high volume water pump, thought about that too (my rad is the 'super cooling' model). Idea is a 7-10lbs of boost. Just thinking a loud......
Love hearinga bout your project! Oh, where did you plumb the return line to the oil pan?
I know this is an old thread, but I have a 94 F150 I would like to turbo. I can do the piping and mechanical but I don't know anything about the computer stuff. I'd like to know how turbo300six took care of the computer adjustments.
We are happy you have chosen the best source for Fords.
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
New update on this old thread. I just rebuilt the engine for my turbo project. I had 5 out of 6 broken top rings. I completely went through everything. Bored .020 balanced, new arp rod bolts, hypereutectic pistons, moly rings, felpro gaskets. and an 11" clutch. Just got it done and in this weekend. Soon I will be ripping out the junk megasquirt fuel controller and installing my own that I am designing and building. My best dyno numbers before the rebuild with 5 BROKEN TOP RINGS !!! were 230HP and 451 Ft.lbs. @ 2800 RPM running 15 lbs boost and burning a 50/50 mix of premium gas and E-85. E-85 works as a great octane booster and a good top engine cleaner. When I took this thing apart I had hardly any carbon buildup on anything. Take a look. MY NEW ENGINE PICTURES ARE HERE AT....
Keep playing with the E85 and you will stop mixing with gas and go straight E85. With the proper tune you won't lose any MPG, you engine will be spotless and power will be up.
Good pictures, I would still use a intercooler even with E85. The cooler the intake charge the better and with the truck you have plenty of room for a good intercooler.
Nice work. My favorite part is the boost controller. If you dyno your new combination please post your new numbers and if possible, a power graph and fuel curve. Thanks.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
