Just turbo'd my 300 six
  #361
Old 03-11-2017, 02:11 PM
BigSixPower's Avatar
BigSixPower
BigSixPower is offline
Originally Posted by Towmanjbo
I was recently looking through some of my old magazines and it the winter 1995 edition of Ford Truckin' there is an article on the E4OD trans and at the time of publication there was a company in CA called Premier Performance Transmissions that sold a standalone computer for the trans. Being that the issue was over 20years ago I have no idea if the company is still in business, they listed their address in Placentia, CA and phone (714) 630-3235.
I forgot to mention that I have a manual, not an automatic, I was assuming since it was a manual, that it would be quite easier to do the swap, excluding tuning and computer work, I can do all the mechanic and fabrication parts myself, but when it comes to the ecu, tuning and computer based parts, I get lost
  #362
Old 03-11-2017, 11:11 PM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
There are two companies that make a controller for the E4OD
One is called bauman and the other is called "US something" i think, I can't remember.
  #363
Old 03-28-2017, 04:35 PM
JP3's Avatar
JP3
JP3 is offline
And a very resourceful fellow in here that made his own.
https://www.ford-trucks.com/forums/1...operation.html
  #364
Old 03-29-2017, 05:16 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
US. Shift and Bauman Controls are the same company
  #365
Old 01-25-2019, 07:31 AM
JD!'s Avatar
JD!
JD! is offline
Turbo setup?
Originally Posted by turbo300six
I just put a borg warner 6.5 chevy diesel turbo on my 89 F150 EFI 300. It works incredibly well the power is amazing. I can easily keep up with a 351. boost starts at about 1500 RPM and peaks out with 9 lbs at 2500-3000. I had to change fuel injectors from 15lbs to 21 lbs 302 injectors. I also had a rich cold start condition that I fixed by adding a resister in parallel with the CTS..Now for the BIG technical question.. Will the factory speed density system run in closed loop utilizing O2 sensor IF the MAP sensor is getting 0inches or positive pressure while the TPS is at half throttle. Also I wonder if the computer in closed loop mode will be able to reduce the pulse width enough on the injectors so it will not be running too rich. I havent yet installed the 02 sensor yet. This thing is great but I am trying to retain some MPG when im not hogging on it.. Any input would be great. Thanks
Hello,
IdI really like to get more info on your Ford 300, 6 cylinder set ups. I'd go go as far as paying you for one.
Please let me know me know.
​​​​​​Thanks, JD
  #366
Old 01-25-2019, 02:33 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,579 Likes on 1,288 Posts
Originally Posted by JD!
Hello,
​​​​​​Thanks, JD
Welcome to FTE!
Scroll back to post 160 in this thread. That was 2008 and the OPs last post in this thread.
The OP last posted anything here on May 2013.
A more current 300/turbo thread with a running, tire-smoking truck is here:
https://www.ford-trucks.com/forums/1...leeper-26.html
annaleigh
01-20-2018 09:59 PM
Glaser67
18
08-17-2017 11:02 AM
Alberta_Mud
16
03-28-2017 06:26 PM
cps123
1999 to 2016 Super Duty
25
01-14-2017 09:09 PM
Thundare
03-21-2011 10:46 PM
Quick Reply: Just turbo'd my 300 six
