Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Supercharger, Turbocharger, Nitrous Oxide and Water/Methanol Injection
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #151 (permalink)
Old 03-16-2008, 07:18 PM
turbo bricklayer is starting off with a positive reputation.
Pic of F150 turbo
  #152 (permalink)
Old 03-16-2008, 07:55 PM
Towmanjbo's Avatar
Towmanjbo is starting off with a positive reputation.
Whoa too much flash, I only see white! LOL
__________________
Justin
1996 F250 XLT Xcab 4x4 7.3 E4OD
1993 Bronco XLT 4" lift w/ 33"s 5.8 E4OD (sold)
1992 F150 Custom/XLT 4x4 4.9 E4OD
1983 F150 Custom/XLT 4x2 4.9 C6
  #153 (permalink)
Old 03-16-2008, 07:59 PM
Towmanjbo's Avatar
Ahhhh in your gallery!
__________________
Justin
  #154 (permalink)
Old 03-16-2008, 08:38 PM
Grey89F250 is starting off with a positive reputation.
Quote:
Originally Posted by cleatus12r
Here's a few numbers for you guys to drool over:
His 300 with 18 PSI of boost (now I think he's limiting it to 10) made 300 HP and 575 Ft. Lbs. at the rear wheels at about 3500 RPM. So I will guess that he's probably at about 260/500 at 10 PSI.
Need more on this truck. ASAP!!
  #155 (permalink)
Old 03-17-2008, 09:32 PM
Yep, how s bout it t36 , pry yourself away from that powerstroke and tell more about that megasquirt your running. Is it best to use it piggyback or could you start from scratch and would it control an e40d? I was thinking about adding a boost timing retard when I get my wb setup and start turning up the boost but maybe I'm going down the wrong road here. By the way I just picked up a 97 pwstr dump yesterday.
  #156 (permalink)
Old 03-18-2008, 12:15 AM
Mtthwvn73's Avatar
Mtthwvn73 is starting off with a positive reputation.
Are you running this without any kind of tunes? I thought for sure this would blow the top out of a piston for sure. I'm going to have to read back and see what's all been done to yours bricklayer.
Matt
__________________
Matt
  #157 (permalink)
Old 03-21-2008, 08:39 AM
Right now all I have is the fmu and I'm not even sure what it is calibrated at. I also rigged a pressure switch to the coolant sensor to try and make sure that the injecter pulse is open as long as possible and right now just running a single wire o2 sensor to my a/f ratio gauge so the engine is always running in open loop. The gauge stays on the rich side even when the turbo spools up so I assume it's maintaining a 14 to 1 ratio even though a 11 to1 would be better under full petal I have to wait to get a wide band setup to tune in to that.Checked plugs, they looked OK.
  #158 (permalink)
Old 04-01-2008, 12:43 PM
Anymore updates? Still have it or did you sell it?
  #159 (permalink)
Old 04-12-2008, 08:22 PM
probly no more till next winter, pretty happy with it for now. I am curious to see how it runs in hot weather. Wonder if anybody else has tried this on their truck yet?
  #160 (permalink)
Old 05-19-2008, 11:59 PM
turbo300six is starting off with a positive reputation.
Hello everyone...It's been awhile..Congrats on your setup bricklayer..It looks good...Well my 89 turbo project is up on ebay...eBay Motors: Ford : F-150 (item 150249481496 end time May-26-08 21:14:35 PDT)
Hopefully a new owner can take up where I will be leaving off
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
