Ford T5 transmission
I'm using buckets.
You might be able to cut off part of the shifter and weld a piece so it extends out a bit?
One from an S-10 won't be able to take the abuse of one from a Mustang. What motor do you want to put this on? If your putting it on a Flathead or any other type of older motor with a custom bellhousing I have no idea where the shifter will end up, if your using 302/351W then it'll be roughtly the same. If you are using a 302 or 351W, you can also try the newer Tremec tranny's, there is one where you can have 3 different mounting points on the tranny, front, mid or rear.
Friends of mine have adapted the stock bellhousing to fit a T-5. Look at www.badgerlandf100s.com for a tech article on how they did it.
Their first one was behind a 223 6Cylinder in a 56. He used a Mustang T-5 but used the tailshaft from a S-10 so he could still use his stock seat. They are made by Borg-warner so they will interchange. Granted, now you will have to buy 2 transmissions or know someone that has access to cores. Hope this helps.
