Spark Plug Change on E-350/V10 - Page 2 - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 05-06-2011, 09:07 PM
EM1/SS(ret) EM1/SS(ret) is offline
EM1/SS(ret) is starting off with a positive reputation.
And we are DONE! Purrs like a REALLY big kitten! No more SES light, still have ABS but thats sensors...Replaced all 10 plugs with autolite plats, didnt need to replace any coils, all their resistances checked sat against the numbers in the Haynes manual. Several of the plugs I pulled were way over gapped, and some of the coils seemed like the springs were stuck up in there and not making contact...
Anyway...10 plugs, a few new toys..er..tools.., PCV, EGR and DPFE...6 codes cleared.
I've decided I am going to let the dealership do the Headers...need the warranty.
Old 05-08-2011, 07:06 PM
Grems4ever's Avatar
Grems4ever Grems4ever is online now
Grems4ever has a very good reputation on FTE.Grems4ever has a very good reputation on FTE.Grems4ever has a very good reputation on FTE.
Congrats on the plug change!
I've had tech problems or I would have jumped in sooner....
Just be sure the coils are plugged in securely - I had #4 come loose while towing last fall.
Old 05-08-2011, 11:21 PM
Bbasso's Avatar
Bbasso Bbasso is offline
Bbasso is gaining momentum as a positive member of FTE.
I'm not looking forward to this... 50K to go
Old 05-09-2011, 07:18 AM
Grems4ever's Avatar
Its not that bad. Just do your research before you start and don't get in a hurry when you're doing it and all will go well.
Old 05-09-2011, 02:20 PM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Quote:
How many miles on your current set of plugs? I wouldn't go past 50K before checking and/or replacing them in these motors.
Maybe I misunderstood something?
Old 05-10-2011, 07:15 PM
Cue the sad cartoon music..
Well..
Changed the plugs and checked the coils...
Still shuddered a little bit, but I convinced myself it not a misfire, must be something loose...like the Exhaust manifold!! $630 later, manifold is on great, new gaskets, studs and bolts...and we're still shuddering..
I'm gonna have to say its a misfire..again..but no codes.
Can I get a list of possible suspects in order of probability..
These are the codes I pulled before I DC'd the battery..
p0171, p0401, p0303, p0304, p0308, p0354
Thanks.
Old 05-10-2011, 08:31 PM
Grems4ever's Avatar
Well, 303, 304, & 308 are misfire codes on cylinders 3,4, and 8.
I suspect that you have some bad coils on there. Before you run out and buy coils, check the boots and springs to make sure you've got good contact between the coil and plug.
1998 6.8 V10 Sparkplug change info wanted Gyrocomp Modular V10 (6.8l) 4 05-07-2014 11:52 AM
Miss in high gear Pxt808 1968-2013 Full Size Vans 2 12-03-2013 09:22 AM
V10 E350 2 valve spark plug change bbcobmike Modular V10 (6.8l) 5 07-02-2013 03:13 AM
E350 v10 sparkplug change moosey78 1968-2013 Full Size Vans 3 07-30-2012 01:45 PM
slight stuttering on acceleration/ COPs? kynnhoj 1968-2013 Full Size Vans 0 12-05-2006 06:45 PM
Tags
1997, 350, coil, e350, ford, mileage, pack, plug, problem, replacement, replacing, rich, running, spark, spec, torque, v10, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
