Help me - Water everywhere
Help me - I can't think, too angry.
Motor finished, minutes from being started and broken in. I was adding water to the cooling system as a final preparation when I notice there is a lot of water pouring off the engine - a lot more than I had spilled. Turns out the drivers head bolt, 4th from the front, 2nd from the back was spewing water. I must have really messed up something somewhere because the 125 ft./lb. torqued bolt was allowing water to pass like nothing at all. Did I put the head gasket on incorrectly? Is something damaged?
On a bright side, the plugs weren't in yet, so the water was about .0005 milimeters from going into the cylinder and causing me even more problems.
Let me know what you guys think - I'm gonna have to put this thing on hold for a while for monetary reasons, I think, but I'd like to know the source of my problem.
-Patrick
-Patrick
I went 90/100 on my edelbrocks. ARP wanted less and edelbrock wanted 100/110. I just looked at a bare block out in the shed and there is a water passage right by that bolt. Looks like the gasket failed. Make sure the surface is super clean the next go - round. That is still a little weird.
Alright - I needed my dads help to get those bolts off. I must say, I am very disappointed with the ARP bolts. Anyway, I would first like to correct my previous statement; in my haste, I said they were torqued to 125 ft/lbs., when in fact, they were 110/100 as per the Edelbrock guy's instructions.
What we found:
Clean and unobstructed surface on both the block and head. A properly installed gasket, (see pictures). No bottoming issues between ARP bolts and Edelbrock Heads.
Most Importantly:
The problem bolt was a lot easier to come off than any of the other bolts. It was NOT torqued to the same degree. How this happened I am not sure, I went around multiple times to check them - but the 'facts is the facts.'
I am hoping I simply missed that bolt while torquing, it would seem reasonable anyway. What do you all think?
Click Here for Pictures
-Patrick
What we found:
Most Importantly:
-Patrick
I am assuming/hoping that I didn't torque that one all the way down - it's the only explanation that makes sense. Do you guys see any glaring mistakes or problems?
In response to your question, that gasket is the Fel-Pro 1020, as was recommended by the Edelbrock guy. The other gaskets "are bull*$&# - use the FelPro 1020 as it has graphite coating," said the Edelbrock guy. The gasket itself seems to be a quality piece, I'll be purchasing a new set tomorrow. Down side to the gaskets is that they set you back $70.
-Patrick
-Patrick
patrick1989
32
06-16-2011 12:00 AM
Rusty_Old_F250
03-31-2011 10:49 PM
patrickke
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
13
11-08-2010 11:03 AM
