97 Explorer Bend Door Actuator Failure - Page 2 - Ford Truck Enthusiasts Forums
Old 04-11-2002, 05:30 PM
freeheeler freeheeler is offline
freeheeler is starting off with a positive reputation.
I have this headache too....unbelievable! How can Joe Consumer be expected to pay over 1000$ to get the heater/ac to work? And how can Ford expect to get return business from him?
I guess I'm lucky. My door is stuck so that I only get heat. A winter in Colorado with only ac would be pretty nipply!
If anyone is giving the slightest thought to persuing this with Ford on a formal basis, please do so!.....and let me know how I can help.
Old 04-19-2002, 10:57 AM
Bobs_Ford Bobs_Ford is offline
Bobs_Ford is starting off with a positive reputation.
All,
I am new to this forum, however, I have this problem with my 97.
Is there a detailed description on how to swap out the blend door ?
I like the idea of epoxy fixing the crack, but do not like the idea of removing the dash.
Do you have to remove the dash ?
Can this procedure be done over a weekend ?
I checked with Ford and it is 6 hrs @ $68/hr plus $110 for parts min.
I would like to attempt to fix it myself but need some guidance, any help would be appricaited.
Thanks.
Bob bobleo@townisp.com
Old 04-19-2002, 01:41 PM
mark0122 mark0122 is offline
mark0122 is starting off with a positive reputation.
I had to replace the plenum box on my '96 XLT a few weekends ago. The dash (and console) does have to come out to remove the box. It is a fairly time consuming repair, but I was able to do it myself with some assistance from a Haynes Manual.
The manual does not cover replacing the plenum box specifically (mainly just assists in dash removal). So be prepared to wing it on some issues that arise. BTW the box at my local dealer was around $110. A lot of headache for a simple piece of plastic (the blend door shaft had broken where the actuator fits into it).
I seriously doubt if you could fix the problem with epoxy. The part of the blend door that had broken off ended up in the bottom of the box, so I don't think you would ever be able to retrieve it without removal of the box.
I did email Ford to see if any financial assistance was offered on what seems to be a known issue... no such luck!
Old 04-19-2002, 08:58 PM
luvmyford luvmyford is offline
luvmyford is starting off with a positive reputation.
I also had the same problem. It put me $700 in the hole to get it fixed. The dealer kept my explorer 2 days to replace the heater box and a blender door motor. The shop manager acknowleged the comonality of this repair. I'm really surprised that a savey lawyer has not picked up on this for a class action.
Old 04-24-2002, 09:31 PM
fyrtrks's Avatar
fyrtrks fyrtrks is offline
fyrtrks is starting off with a positive reputation.
For what it is worth i filled out a generic complaitn here.
<!-- www.bigclassaction.com --> Guideline violation removed.
Let's give some of Ford's money to somebody cause they won't spend on us.
Old 04-25-2002, 10:16 AM
Ford 4 Life Ford 4 Life is offline
Ford 4 Life is starting off with a positive reputation.
I had the very same problem 1 month ago. I took my 1997 Ford Explorer Eddie Bauer to the dealer for a diagnosis ($60.00). They told me that the Bend Door actuator was stuck in the close position which would not allow heat to escape. They wanted $1010.00 to fix. I said
"no thanks".I then took it to a recomended mechanic who replaced the entire heat box unit. He told me that it would be cheaper to replace the entire unit rather than just the bend door itself. He charged $720.00. It works good but I still don't get the right tempurature all the time. If I have it set to 82 degrees, it will heat the truck up for a little while then the air turns cold. I then have to turn the temp. to 90 degrees to get heat out. I wish I had the same heat as my Ranger, that works awsome.
A freind of mine has a Jeep Grand Cherokee with the electronic heating system and it works great, easy to use and never once had a problem with it.
Ford should suck it up and call Jeep for suggestions.
Greg
Old 04-26-2002, 11:53 AM
hank_48 hank_48 is offline
hank_48 is starting off with a positive reputation.
If you are affected by the blend door issue, be sure to check out vote at the post listed below:
Who has or is having a blend door problem?
It should be of interest to those of of affected by this problem.
Old 05-16-2002, 11:42 AM
gbraunst gbraunst is offline
gbraunst is starting off with a positive reputation.
hank_48 - You seem to have forgotten to include the link to the site you mentioned above. Can you post that? I'm currently in the midst of a fight with Ford over the defective blend door in my 96 Explorer.
I have the Eddie Bauer edition, with the electronic thermostat control, and the problem I'm experiencing is that if I set the thermostat to a specific temp. (let's say 68), then the a/c will blow cold until the temp. gets down to that desired temp.; but once it hits it, it then blows flat-out hot. So it sways back and forth from hot to cold with nothing in between.
Thanks.
Old 05-16-2002, 12:31 PM
[updated:LAST EDITED ON 16-May-02 AT 01:52&nbsp;PM (EST)]This is actually a post on the current link. Its back a page or 2 and dated Apr 24, 02 by author "fyrtrks". It doesn't look like it updates the date whenever someone responds to the poll.
Good luck on your fight with Ford.
I just found an excellent article about the blend door issue: http://www.mightyap.com/Data/otl1200.pdf
At the end of it, there is information on how to report this as a SAFETY ISSUE to the NHTSA. You'll need the VIN, then go to www.nhtsa.dot.gov/hotline or call 1-888-327-4236.
Okay, now everyone who has this problem - get online or call. Let's get Ford to do the right thing!
Old 06-26-2002, 05:31 AM
khartmann khartmann is offline
khartmann is starting off with a positive reputation.
Post 97 Explorer Bend Door Actuator Failure
[updated:LAST EDITED ON 26-Jun-02 AT 06:31&nbsp;AM (EST)]hello edamon
i'have the same EATC problem and think it will be the actuator. can you send me Alldata...
i'm very interested in the pinpoint test. have you any informations about it (wiring...)
thank you v.m.
kh
Old 07-01-2002, 02:29 PM
daria daria is offline
daria is starting off with a positive reputation.
[updated:LAST EDITED ON 01-Jul-02 AT 04:01&nbsp;PM (EST)]Yet another Ford owner with the same problem. The blend door on my '97 Explorer Sport with only 57,000 miles broke this past March. I've been quoted $500 for the repair, which I refused to pay for a defective part.
Three phone calls to their customer service line, two trips to the local Ford dealer, and an appeal to their dispute resolution board have yet to solve the problem...my latest try has involved letters enclosed with an inch of supporting documents to Ford World Headquarters, Ford Executive Offices and the CEO and Office Operations Manager of their Minn. customer service division.
It's ridiculous that Ford won't take responsibility for what is obviously a very prevalent problem that stems from their manufacturing plants. So, I've come to the conclusion that I'm not beneath involving a lawyer if my letters don't result in a satisfactory outcome.
I'll be sure to fill you all in when my problem is solved so you know the shorter route to take to resolution.
Daria
PS. Thanks for the info, fyrtrks, I too filled out at complaint form at <!-- bigclassaction.com. --> Guideline violation removed.
Old 11-26-2002, 04:08 PM
bfisher bfisher is offline
bfisher is starting off with a positive reputation.
I have the same problem with my blend door breaking. Dealership wants $830. Here is a site to help everyone out hopefully. I just found the info, so I have not yet tried it.
http://www.proacshops.com/accum-March-April%2020011.pdf
According to this you can replace the door without removing the dash. Let me know if this looks like a option that will work
  #28
Old 12-23-2002, 09:30 AM
erose1422 erose1422 is offline
erose1422 is starting off with a positive reputation.
>I've got the Alldata on this.. if anyone wants it, email me.
>anyhow, here's the useful test I'll do later on:
>Drive actuator in both directions while visually checking
>actuator for movement.
>1. If there is movement, remove actuator and visually che6k
>blend door where the actuator rod inserts for cracks. The
>instrument panel does not have to be removed for this
>operation. If the door is cracked, order a service plenum.
>Refer to the Service Plenum Tips in this article.
>2. If there is no movement, diagnose system according to
>pinpoint tests in the appropriate Explorer/Mountaineer
>Workshop Manual.
  #29
Old 12-23-2002, 09:32 AM
Please send me the Alldata on this. My email address is: erose1422(No Email Addresses In Posts!). Thanks.
  #30
Old 01-06-2003, 10:17 AM
tkrone tkrone is offline
tkrone is starting off with a positive reputation.
Any update with this blend door problem and FORD?? I just got the same failure on my 97 Sport..
Tim
07 Expy Driver's Blend Door Actuator rexpedition99 2007 - 2014 Expedition & Navigator 3 03-13-2017 11:52 AM
99 Expedition replace blend door - cut hole method rexpedition99 1997-2006 Expedition & Navigator 4 12-02-2015 01:14 PM
Stuck 04nbx Cooling, Heating, Ventilation & A/C 0 04-20-2015 07:28 AM
Blend door actuator- Defrost issue dilas 2004 - 2008 F150 4 10-27-2011 06:51 AM
97 Explorer XLT Bend Door Actuator Failure rkasj Cooling, Heating, Ventilation & A/C 13 12-16-2003 09:42 PM
Tags
1997, 2002, actuator, controls, door, eatc, explorer, flow, ford, heater, mode, motor, perform, problem, temperature, troubleshooting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
