93 Ford Explorer Losing Coolant - Ford Truck Enthusiasts Forums
Old 01-03-2003, 12:31 PM
KSU_Cowboy KSU_Cowboy is offline
KSU_Cowboy is starting off with a positive reputation.
Post 93 Ford Explorer Losing Coolant
Have a 93 Ford Explorer with the 4.0 Litre, have replaced the radiator, all hoses, raditor cap, thermostat, water pump, had a 10 minute pressure test performed and losing coolant. Engine does not miss or backfire no visible signs of where coolant is going. Replacing close to a gallon a week ideas? Do seem to have an abnormal amount of condensation out of exhaust pipe. Think maybe a bad headgasket, cracked head, or intake manifold gasket, just need some confirmation or test I can use to help determine the need to tear into the engine.
Old 01-03-2003, 05:35 PM
460429_freak's Avatar
460429_freak 460429_freak is offline
460429_freak is starting off with a positive reputation.
mine would seep out the front intake gasket by the thermostate you couldn't see it but you could get a wiff of it then it blew one day we replaced the intake gasket but then the head gasket started to leak
FORDS always look better when pulling a CHEVY
Old 01-03-2003, 05:42 PM
mrshorty mrshorty is offline
mrshorty is gaining momentum as a positive member of FTE.
My '92 used to use coolant before I tightened the lower intake manifold bolts.
Old 01-03-2003, 08:33 PM
mgazak's Avatar
mgazak mgazak is offline
mgazak is starting off with a positive reputation.
My 92 also liked to drink coolant (not like in the first post, though). Never had a problem with the engine otherwise and couldn't find where it went. I traded it at 120,000 miles.
I have to add some coolant on 98 w/ the pushrod occasisionally, but it doesn't seem to like it as much as the 92.
Old 01-03-2003, 09:15 PM
samhihn samhihn is offline
samhihn is starting off with a positive reputation.
Hmmmmm Whatever it is isn't normal. I'm voting head gasket. Whatever it is keep in mind that your O2 sensors don't like smelling anti-freeze. Check your spark plugs....a really "clean" one can mean that cylinder has been burning water. If coolant hasn't been maintained properly there is also a good chance you could have a freeze plug leaking. The intake manifold is also prone to leak at the gasket and sometimes re-torqueing can solve that.
Old 01-07-2003, 11:03 PM
rowiebowie rowiebowie is offline
rowiebowie is starting off with a positive reputation.
My '95 was loosing a quart a week with no visible drip anywhere, (frustrating). Checked everything I could think of with no luck. Finally it turned out to be the heater valve on the hoses near the engine firewall. Was dripping on engine and evaporating. No too expensive or hard if you have to replace. Good luck, ROY:-)
Old 01-08-2003, 07:42 AM
FortyFords's Avatar
FortyFords FortyFords is offline
FortyFords is gaining momentum as a positive member of FTE.
Do you smell antifreeze in the interior ?
Chk your heater core ,pass side ,lift the carpet look for wetness.
Look for bubbles in the coolant if you think headgasket.
If your losing that much ,you'll find it!
Rich
02 F250 4x4 SC 5.4v8 6spd 3.73ls Trueblue/Silver and Chrome Nerfs
"All Levers"
Old 01-09-2003, 09:39 PM
larry2c larry2c is offline
larry2c is starting off with a positive reputation.
I have a '93 XLT with 110K on it and started noticing coolant dissapearing a while back. The morning I wanted to leave for Big Bear with my family, it finally decided to reveal where it was leaking. After driving about 3-4 miles and stopping, there was a flood of coolant pouring out around the starter. Turned out to be the gasket failed at the rear passanger side of the intake manifold.
Sounds like this is fairly common
Old 01-10-2003, 07:10 AM
SplashMan's Avatar
SplashMan SplashMan is offline
SplashMan is starting off with a positive reputation.
coolant leak? With picture cmsslates 1999 - 2003 7.3L Power Stroke Diesel 6 07-21-2014 11:40 AM
Coolant Pressure Fluctuations/Losing Coolant sherLocke9 1987 - 1996 F150 & Larger F-Series Trucks 11 03-04-2014 08:31 PM
2003 exploer leaking coolant from crankshaft stcspiderman Explorer, Sport Trac, Mountaineer & Aviator 4 01-21-2014 12:44 AM
Coolant Loss Out of Degas Bottle DieselE 6.4L Power Stroke Diesel 27 11-28-2012 08:28 PM
2003 Ford Explorer Power Failure garciat Explorer, Sport Trac, Mountaineer & Aviator 20 04-06-2007 10:35 PM
Tags
2000, 2002, antifreeze, check, coolant, explorer, f150, ford, gasket, head, intake, leaking, leaks, losing, manifold
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
