Rear diff and trans codes
I have a 1986 F150 302 4X4 automatic w/ overdrive. The driver side door codes are all removed, so I am unsure what rear end and trans I have.
I pulled the codes off the rear end and trans, any help is greatly appreciated.
Trans code:
RF-E39P-7006
Rear end code:
5910P
55 88 6C03
Also, would the rear end be limited slip? I am assuming that it is not because when the rear tires are off the ground and I turn one tire, the other one turns in the opposite direction.
Thanks
Trans code:
RF-E39P-7006
Rear end code:
5910P
55 88 6C03
Thanks
TonyJestis
36
04-14-2009 03:44 AM
35Rem
04-17-2006 06:16 AM
