You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I have a '52 V8 and am wondering what the bent tube coming out of the intake next to the oil breather is for? It takes a 90 degree turn and goes down behind the drivers side waterpump where it goes back into the block.
I have the FMC shop manual but can't find any mention of this tube.
Thanks
__________________
Gary V.
37 Ford in a Ford
'06 350 Diesel, 6 speed
Wife drives a J**P Wrangler
It's the road draft tube. I think if you look closer, it doesn't go into the block at the bottom. It should be cut off at an angle and the end is open. While your vehicle is moving, a vaccuum is created at the end of this tube. Air is drawn in the oil filler tube, thru the block and exits at the road draft tube. Crankcase ventilation in it's simplest form. ...Terry
__________________
It is a simple task to make things complex,
but a complex task to make them simple.
Thanks Overkill. So if one wanted to recirculate those gases it would do to divert that tube to an adaptor plate under the carb. I will look for threads on EGR/PCV to see if anyone has done that. I am adding a 390 CFM, should be easy to get an adaptor for that, if is't workable. Probably have to seal the old breather.
__________________
Gary V.
37 Ford in a Ford
Blocking the road draft tube and connecting a pcv to it seems to be the way to increase the crankcase ventilation. The oil filler cap has filter material in it (but not very good stuff) to filter the incoming air. You will have to keep the air flowing into the filler tube, but you could do a better job of filtering it. ...Terry
__________________
