1994 Explorer Heater core Removal & Installation - Ford Truck Enthusiasts Forums
Old 01-12-2003, 03:43 PM
BigEarlW BigEarlW is offline
BigEarlW is starting off with a positive reputation.
Post 1994 Explorer Heater core Removal & Installation
I need some expertise on how to remove & replace a heater core. Step by step would be nice with some diagrams if possible.
Thanks
BigEarlW
Old 01-12-2003, 08:25 PM
mrshorty mrshorty is offline
mrshorty is gaining momentum as a positive member of FTE.
www.autozone.com has vehicle repair guides that are the equivalent of a Chilton's manual. The heater core replacement is in the chassis electrical section of the manual.
Old 01-13-2003, 06:54 PM
ckrichard's Avatar
ckrichard ckrichard is offline
ckrichard is starting off with a positive reputation.
very easy. just one tip to give you. to remove those little black clips use a pair of nettel nose and stick the tip of them inbetween the base and the head of the clip, then open the pliers and they will pop right off.
Chris
Old 01-15-2003, 06:25 AM
marragtop's Avatar
marragtop marragtop is offline
marragtop is starting off with a positive reputation.
Also, when reinstalling the core, it's best to have a 2nd pair of hands. You'll need one person under the dash to push the core up and thru the firewall, and another person under the hood to help guide and grab it. The whole job shouldn't take more than an hour.
Mike
Old 01-15-2003, 07:55 AM
jshooten jshooten is offline
jshooten is starting off with a positive reputation.
98 5.4L heater core replacement FordGurl83 Modular V8 (4.6L, 5.4L) 2 11-03-2014 07:54 AM
Heater hose removal victorcharlie 1999 - 2003 7.3L Power Stroke Diesel 5 11-21-2011 04:31 AM
1990 ford f250 heater core replacement vynck143 1987 - 1996 F150 & Larger F-Series Trucks 4 10-05-2011 05:30 PM
heater core hose removal??? zed326 1997-2006 Expedition & Navigator 3 01-28-2009 05:14 PM
HELP! F350 Heater core leaking Fairmont RV 1999 to 2016 Super Duty 3 01-21-2007 07:52 PM
Tags
1994, change, core, explorer, ford, heater, removal, replace, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
