Go Back   Ford Truck Enthusiasts Forums > Misc. > Oil & Lubrication
New! Use your Facebook to securely log into this site, click logo to login
Oil & Lubrication NO MLM Dealers, Wholesale Buyers Or Retailers allowed (except sponsors)
SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-11-2004, 03:10 PM
pdqford pdqford is online now
pdqford is starting off with a positive reputation.
Ford Oil Spec#
My '79 Shop Manual calls for the following:
ESW-M2C119-A Hypoid Gear Oil
ESP-M2C83-C Standard Transmission Lube
Can anyone direct me to a cross reference to lubes I can find in the stores?
(None of the oil bottles I've looked at carry these spec #s)
Thanks in advance for any responses:
__________________
Jim in Central NY
'79 2WD F-150 Lariet w/302,4spd OD, 228,965 mi. (Original Owner!)
'02 4X4 Navigator w/5.4L DOHC 32v Intech V-8.
  #2 (permalink)
Old 06-11-2004, 07:23 PM
BlueRanger94 BlueRanger94 is offline
BlueRanger94 is starting off with a positive reputation.
Those specifications are to out of date to be found on a current oil container. I would check a Chilton book that covers that year and see what it says.
  #3 (permalink)
Old 06-11-2004, 09:38 PM
Quote:
Chilton says to use "Hypoid Gear Lubricant SAE 80 or 90" in rear axle and to use "SAE 90 or 80 transmission lube" in the manual transmission.
I have found 80W-90 Hypoid Gear Oil for the rear end, but haven't been able to find the SAE 90 or 80 transmission lube.
When I ask the counter person for transmission lube, they want to sell me either ATF or Hypoid Gear Oil. I've been told the Hypoid Gear Oil is not good to use with the brass syncros in standard transmissions.
What do all you guys use in your standard transmissions?
__________________
Jim in Central NY
  #4 (permalink)
Old 06-11-2004, 10:51 PM
TallPaul's Avatar
TallPaul TallPaul is offline
TallPaul is starting off with a positive reputation.
Check with Redline Oil. They have tranny lubes that don't eat yellow metal. And it is some of the best gear lube available.
__________________
'95 F150 XL, 2wd, 300 I6, 5 speed, 3.08 gear, 166,000+ miles, Flowtech Raptor muffler, driven hard for fun!
'92 Aerostar 3.0 Vulcan V6, auto, 134,000+ miles, Dynomax Super Turbo muffler
www.HonestEdu.org
  #5 (permalink)
Old 06-11-2004, 11:45 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a name known to allRockledge is a name known to allRockledge is a name known to allRockledge is a name known to allRockledge is a name known to allRockledge is a name known to all
Use a good Mercon-rated ATF in your standard transmission and you should be fine.
__________________
'98 Ranger XLT 4x4 (4.0L)
'97 Taurus GL (3.0L Vulcan)
'94 Taurus SHO (MTX)
Ford Pics
  #6 (permalink)
Old 06-12-2004, 09:10 AM
Just wanted to thank BlueRanger94, TallPaul, and Rockledge for their comments. Apparently their is not a way to convert an old Ford Oil Spec # (the best the Ford Dealer could do was to say that its an "obsolete" spec #) to a product that is currently available.
I've been reading the various sites that have been recommended to me and searching the internet for more info. Soon I'll have to make the choice.
(ATF?, 50#motor oil?, Hypoid gear oil?, GL-4/MT-1 spec oil?, Marine Lower Unit Gear Lube?, Dino oil?, Synthetic?, 75W-90 weight?, 80W-90 weight?, 75W-140 weight? AmsOil?, Mobil-1?, Redline?, Royal Purple?, Valvoline?, decisions, decision. . . . . )
__________________
Jim in Central NY
  #7 (permalink)
Old 06-12-2004, 03:00 PM
Frank D Frank D is offline
Frank D is starting off with a positive reputation.
My son's 4 wheeler ATV uses 80w transmission oil in it's trans. It is available in motorcycle shops. I don't know if it can be used in your truck's trans but maybe you can look into it.
Tags
80, 90, cross, espm2c83c, eswm2c119a, ford, gear, hypoid, lubricant, mt, oil, reference, sae, spec, yn12c
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive -
Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
