Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford ExplorerSPONSORED BY:
  #1 (permalink)
Old 01-14-2003, 08:25 PM
cecil cecil is offline
Garage is empty, add now
cecil is starting off with a positive reputation.
code p1309
1998 explorer
5.0 engine
computer scan says code p1309
p1309 is misfire moniter aice chip fault
does any one know how to correct this
  #2 (permalink)
Old 01-14-2003, 11:57 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
code p1309
A P1309 is a camshaft position sensor code. The manual says to hook up a breakout box and monitor the voltage from it. If it isnt right you replace the sensor.
__________________
Dave - FTE moderator
Forum Guidelines
this space for rent
  #3 (permalink)
Old 01-15-2003, 07:30 AM
code p1309
http://www.contour.org/FAQ/FAQ.php?s=probs&displayid=10
this site says it is misfire monitor problem
i have already replaced cmp per code p0340
thanks
confused
  #4 (permalink)
Old 01-15-2003, 11:27 AM
Racerguy's Avatar
code p1309
This is right out of the Ford shop manual........
HD40 CHECK CMP SENSOR OUTPUT
Diagnostic Trouble Code (DTC) P1309 indicates Misfire Detection Monitor is not enabled.
Breakout box installed, PCM disconnected.
Connect digital multimeter between PCM test pin 85 and test pins 51 or 103.
Bump engine in short burst with the starter without starting engine for at least 10 engine revolutions.
Does digital multimeter reading switch between low (less than 2.0 volts DC) and high (greater than 8.0 volts DC)?
Yes
Note: A Hall effect type CMP sensor that is installed out of synchronization will produce a DTC. VERIFY the correct installation by referring to the Powertrain/Engine Group in the Workshop Manual. If the CMP is installed properly, REPLACE PCM. RESTORE vehicle. RERUN Quick Test .
No
REPLACE CMP sensor. RESTORE vehicle. COMPLETE Misfire Monitor Repair Verification Drive Cycle. RERUN Quick Test .
__________________
Forum Guidelines
this space for rent
  #5 (permalink)
Old 01-16-2003, 03:04 PM
code p1309
thank you very much!!!!!!!!!!
  #6 (permalink)
Old 01-16-2003, 06:59 PM
jaystersj jaystersj is offline
jaystersj is starting off with a positive reputation.
code p1309
Tags
2000, 50, aice, chip, code, definitions, dtc, explorer, f150, fault, ford, misfire, monitor, odbc, p1309
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
