98 explorer sport (power loss)
Old Jan 12, 2003 | 03:43 PM
jaystersj's Avatar
jaystersj
Hey everyone. I'm just wondering if anyone knows , or has had the same problem with their explorer that i'm having. My Explorer sport is surging when at a constant speed and feels as if it has lost alot of power. I changed the wires since one was cracked, but it still does it. I'm just looking for a few ideas about what maybe it should be, since i have to sink another$400 into it this week for a hub assembly.. Any assistance would be greatful..
Thanks Jay
Old Jan 14, 2003 | 06:36 AM
SplashMan's Avatar
SplashMan
Clean your MAF, IAC and throttle body. Make sure you use varnish safe throttle body cleaner on the throttle body and 02 safe cleaner on the MAF. May want to check the serpentine belt for slippage or looseness. Lastly, make sure you disconnect the battery while doing the cleaning.
Old Jan 14, 2003 | 07:16 AM
FortyFords's Avatar
FortyFords
Jay ,did you have it scan for codes within the computer ?
some times codes will be posted even if no chk eng light comes on!
All of the above posted was correct ,you could be developing leaking
lower intake o-rings also.
Just my opinion
Rich
02 F250 4x4 SC 5.4v8 6spd 3.73ls Trueblue/Silver and Chrome Nerfs
"All Levers"
Old Jan 15, 2003 | 06:21 PM
jaystersj's Avatar
jaystersj
thanks for your help guys! But whats the MAF and IAC?
Old Jan 16, 2003 | 06:27 AM
SplashMan's Avatar
SplashMan
Your MAF is located at the end of your air intake tube(oposit the throttle body). It is the flat black box right after the air box. The IAC depends on your engine. On my SOHC it is located on top of the engine under the "SOHC" cover.
Old Jan 16, 2003 | 06:59 PM
jaystersj's Avatar
jaystersj
Thanks again, I looked in my book, i could've figured it out, i'm so stupid sometimes,,. I'll try everything, its really starting to **** me off. I'm going to change the plugs to(92k). Maybe it will help
thanks again
Old Jan 16, 2003 | 07:03 PM
ROFFL's Avatar
ROFFL
Post 98 explorer sport (power loss)
Mikeman
Jul 18, 2013 05:27 AM
fordblue_ca
Nov 17, 2006 08:25 PM
smcget
Feb 3, 2005 05:16 PM
ytee
May 26, 2004 06:35 PM
JOSEPHLB
Dec 10, 2003 08:10 PM
