Bronco II leaks - Page 2 - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
Bronco II leaks
Old 01-14-2005, 09:15 PM
Big-Joe Big-Joe is offline
Big-Joe is starting off with a positive reputation.
Winddancer, I am glad that there are so many of these trucks still on the road. Personally I think they out perform the chevy blazer that is "comparabe" cough to it and can even give the Jeeps a run for their money. As I said it you are doing interior or exterior mods then check out LMCtruck.com and get a catalog, it might help you. I also have the blue interior in my '89 gen II BII if you find a good place for carpeting please let me know, actually I'd rather have the rubber flooring used in the police package explorers if anyone has any information on that I'd be glad to hear it. Thanks again. *Joe*
Old 01-14-2005, 10:39 PM
likenewbronco2's Avatar
likenewbronco2 likenewbronco2 is offline
likenewbronco2 is starting off with a positive reputation.
Winddancer, I've also pretty much gutted,cleaned, painted and/or replaced most of the interior of my 85 BII, but I'm still stuck with the crappy "low back" bucket seats. I threw on a cheap set of set covers, but I'm looking for a nice set of replacements that aren't going to cost more than an engine swap. I've been through a few junk yards looking for something that will work, but most of those seats are in worse shape than the one's I've got. Any suggestions?
Old 01-15-2005, 03:47 PM
winddancer's Avatar
winddancer winddancer is offline
winddancer is starting off with a positive reputation.
likenewbronco2-
I am going to use the seats out of a arostar van. They say they will mount up to your tracks and bolt right in. First I will have them recovered. The junk yards here are full of arostars. And the seat is much more comfortable.
Bigjoe-
I found a bunch of places on the net to get the carpet or the vinyl floors. I need to check again as I lost some of my favorites when I switched to a new type of browser.
The blue interior realy sucked since the truck was used as a mechanics truck for a bus company before I got it.
Old 01-15-2005, 07:29 PM
winddancer's Avatar
Here is one of the places I was looking at for the carpet or vinyl:
http://www.automotiveinteriors.com/c...lete_order.htm
Old 02-06-2005, 01:36 PM
johnes50 johnes50 is offline
johnes50 is starting off with a positive reputation.
Thumbs up
ikenewbronco2
I have an 86 BII that had the notorious broken driver side seat back. I swapped in a set of 60/40 high back seats from an 86 Ranger. They feel much stronger and I have a nice place to lay a map when I have a passenger along. The floor bolt pattern is an exact match and the seats bolt right in. And I forgot to mention the drivers seat has a fold down right armrest.
Old 01-15-2014, 04:58 PM
weldchick weldchick is offline
weldchick is starting off with a positive reputation.
driver side on my B@ wet also, removed fender and found where body meets firewall seam rusted terribly and starting to seperate.. cleaned out cowl before and no difference.. i think i found my culprit, good luck!! maybe this helps.. maybe not..
Old 01-16-2014, 07:58 AM
Josh S Josh S is online now
Josh S is gaining momentum as a positive member of FTE.
Quote:
This thread is 9 years old.
Are you planning to fix your rust problem? If so there's a more current thread on this topic going on in the Ranger area that you're welcome to piggyback.
http://www.ford-trucks.com/forums/12...st-damage.html
Welcome to the forum!
Old 02-13-2014, 11:19 AM
Bills86e Bills86e is offline
Bills86e is starting off with a positive reputation.
interior wet
Most of the time its that the windsheild cracked, or firewall has rust hole.
Sometimes the A/C pan drain gets clogged up and then drips onto your carpet. This goes un-noticed until the carpet smells like mold/mildew,even
rots out the floor pan.
Bills86e
Question of the Week Bronco or Bronco II? Patrick R. General Automotive Discussion 7 06-26-2016 03:41 AM
Can I float gears in a 88 bronco ii 5 speed? MrCorter 1978 - 1996 Big Bronco 1 04-18-2016 12:06 AM
'90 Bronco II coolant leak mystery jchandler11 Bronco II 12 12-22-2015 06:53 AM
1988 Bronco II water leaks in the cab lgamech Bronco II 6 10-15-2013 11:03 PM
Bronco II broke77f100 Bronco II 16 12-13-2006 04:40 PM
Tags
88, bronco, carb, carpets, firewall, ford, front, fuel, ii, leak, leaking, leaks, ll, rain, v6, windshield
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
