Rear end tag decode? WCR-R1 3.50 6BA 782
Old 06-25-2004, 10:53 PM
rawdawg's Avatar
rawdawg
rawdawg is offline
Unhappy Rear end tag decode? WCR-R1 3.50 6BA 782
I dont see this tag number listed in the reference they have on this site and was wondering if somebody could clue me in . Thanks
Old 06-27-2004, 12:45 PM
grclark351's Avatar
grclark351
grclark351 is offline
what year is it? i have the 72 shop manuals, sometimes the codes are good for a number of years. it looks like a 3.50:1 open gear, what other info are you looking for?
Old 06-29-2004, 11:47 AM
rawdawg's Avatar
rawdawg
rawdawg is offline
I was wondering if it was a posi. Thanks, when I jacked up the rear, both wheels spun the same way.
Tony
Old 06-29-2004, 06:08 PM
grclark351's Avatar
grclark351
not by the tag, but anything can be in there. if it was an original tagged Trac-Loc it would give the ratio as 3 L 50. could be someone put a Trac-Loc carrier in and replaced the tag to let whoever know what gear is in it? or could be someone did a five cent posi? this is just shimming the center tight by putting an extra shim behind the axle side gears. if you jack one tire off the ground, with the trans in park, how hard is it to turn the lifted tire? it should turn with considerable resistance if the clutches are good. listen for chatter or any other noise when it breaks loose.
HANDSOME
20
10-27-2015 08:30 PM
cstempert
02-24-2015 10:52 AM
Flight_RN
1999 to 2016 Super Duty
03-01-2014 10:37 AM
jyblood
02-16-2014 03:25 PM
Palumbo
12-01-2003 12:12 PM
Quick Reply: Rear end tag decode? WCR-R1 3.50 6BA 782
