460/Powerstroke Diesel transmission bolt patterns - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 08-31-1999, 05:12 PM
Junkyard Slug Junkyard Slug is offline
Junkyard Slug is starting off with a positive reputation.
This might be way off, but I herd a rumor that the Powerstroke Diesel and Big blocks shared transmission bolt patterns. The reason I ask is I have a 86 Big Bronco with a mildly built 460 and a C6 auto. I would like to swich to a manual transmission, perferably the M6OD, offered only behind the current Powerstroke equiped trucks. The M6OD seems like a good canidate, as it is a 6 speed with a granny gear (over 5:1) and an overdrive, and are rated at 500 ftlbs of torque. I know for a year or two the 460 and PSD were offered at the same time, and shared simalar transmisson options, but I don't know about the bolt patterns. Any thoughts would be apprecated.
Old 09-01-1999, 06:32 AM
Deen Hylton
Guest
Posts: n/a
You might try calling Ford Motorsport Tech Hot Line at (810)468-1356 they are open 10:00 AM-6:00PM Eastern Standard Time. Be prepared to sit on the phone a while...they get a lot of calls.
Old 09-02-1999, 02:15 PM
deleontow deleontow is offline
deleontow is starting off with a positive reputation.
Clutch & Pressure Plate bolt patterns. 51M1 Clutch, Transmission, Differential, Axle & Transfer Case 0 12-14-2014 09:42 PM
400M Shadowrider123 1961 - 1966 F-100 & Larger F-Series Trucks 2 07-07-2014 02:01 PM
'77 F250 460 EFI swap Ordnance 1973 - 1979 F-100 & Larger F-Series Trucks 3 02-12-2014 09:25 AM
16.5 x 9.75 OEM steel rims on a 150? Banksva 1973 - 1979 F-100 & Larger F-Series Trucks 2 12-10-2013 02:02 PM
What Bell Housing Bolt Pattern For The 351c???? 80-F-250 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 1 06-10-2006 01:07 PM
Tags
1997, 460, 73, auto, bolt, c6, diesel, ford, m6od, patterns, powerstroke, speed, t0, tranny, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
