Painting Inside Intake Manifold
Anyone ever done this?A retired ford mechanic said they would sometimes do this,using epoxy,or an epoxy paint.What is the benefit,what are the risks,and does anyone have reccomendations as to methods/materials?Thanks gentlemen...and gentlewoman,er,person, Janet...Dear!
Sounds a wee bit insane. Might work.
Perhaps a smooth epoxy coating would 1.) affect the flow... though there is something about boundary layer air that wants broken up. 2.)The volume of the intake would be reduced... though not much depending on the application. 3.) This may have been a way to fix a crack from the inside.
I don't see a benefit in either of the first two notions above. I guess in desperation you could repair a crack in the manifold from the inside. Who really knows? The down side appears to be that you would be messing up a perfectly good intake manifold or not fixing one that is already messed up.
I'd avoid putting epoxy down my intake, Buzz. best. himmelberg
on
coating intakes
I'm no fuel intake expert... I'm still studying to get to rookie grade...
but I thought the rough finish helped keep the atomization up...if it's slick it tends to puddle ??? I know I remember that from somewhere didn't I ???
It might be a different thing in full blown race engines... but on the street with different throttle positions and varying vacuum... I don't know ???
john (dumb...but cool)
I believe, as suggested, that intake manifolds have been coated to seal them up because they failed a leak test due to porosity. I would expect that this coating is very thin, just enough to seal, and that it is certainly compatible with fuel. I have heard of this as a repair/rewqork procedure for OEM parts to the engine plant so the caoting would have to have been OEM approved and tested.
Regards, John
Regards, John
Intake upper and lower
I was told by cleaning my plastic intakes with carb and choke cleaner it would strip away a special coating they put on them at place they make intakes. Can anyone confirm if they do this and if they do can I buy it to re coat them on the inside. So if this is true I would not spray anything inside, cause this coating is supposed to reduce carbon buildup
Throttle body,
Woo! Cool, so wheny say throttle body you are referring to the metal piece that attaches to the front of upper intake/plenum with the round air adjustment flap right?
Thank you brother, I'm trying to get this new 4.0l v6 sohc mfg before 03/00 installed and the mice have chewed all my stickers off that go with my steps to re install. 😵
CharlieLed
30
10-23-2016 12:45 PM
