6.9 auto to manual conversion
Old 10-05-1999, 07:09 AM
roger's Avatar
roger
roger is offline
Would like to convert my 86 F-350 4x4 6.9Diesel to manual using a NP435.have everything figured out except clutch.Ihave aluminum bellhousing ,flywheel and clutch from another 86 but I want to use mechanical clutch linkage instead of hydraulic.I have all the clutch pedal brackets and linkage out of an 80 f-350 and made my own equalizer bracket.Did Ford ever put an iron 6.9 bellhousing with mechanical setup on any truck?my book said 83 could have a 12 clutch.The clutch fork from a hydraulic does not have leverage to be used mechanically and that is the problem.
Old 10-07-1999, 09:10 AM
delentow
Guest
Posts: n/a
In early 83 Ford did make a non hydraulic clutch. Though it is very rare and hard to find.
Good luck
Dave
Old 10-16-1999, 07:02 PM
PHIL SALES
Guest
Posts: n/a
you may want to look into parts from IH trucks since that engine is theirs origionally.good luck PHIL
Old 10-23-1999, 02:45 PM
ray's Avatar
ray
ray is offline
Bulldog f150
29
02-07-2014 09:44 AM
ATC Crazy
07-23-2013 12:01 PM
jeep-rally
WTB - Parts & other
12-29-2012 02:54 AM
Ford59galaxie
70
03-07-2012 10:43 PM
junkyardjeff
01-05-2012 05:57 AM
Quick Reply: 6.9 auto to manual conversion
