Maf Sensor Question
Maf Sensor Question
I have a 94 aero w/ 82k miles. I cleaned my maf sensor following all of the instructions. However, I forgot to plug it back in. The problem is that I had no problems - no fault codes - no poor mpg, nothing. I read somewhere that the engine should not have run at all w/o this plugged in (or at least activated the check engine light - yes it lights when starting engine but goes off normally). I took it to autozone & checked if any codes - nothing.
Is this normal, or what should I look at
Thanks
Thanks
NOW... I have done this accidentally, when I was trying to figure out a rough idle problem (vacuum hoses) but I got the engine light immediately. Could it be that without the MAF sensor working it reverts to a set table for engine RPM until it is corrected? Odd that the light didnt go off though.
Originally Posted by felixdacat76
Off the subject a bit, would changing out the MAF to an aftermarket one (such as a Granatelli) help out noticeably with a 3.0L V6 Ranger? Any advice would be appreciated, thanks!
