Parking Brake Adjustment on 2000 Expedition - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 06-09-2004, 06:09 PM
kangg kangg is offline
kangg is starting off with a positive reputation.
Question Parking Brake Adjustment on 2000 Expedition
Hi. I have a 2000 XLT expedition. Does not have air ride suspension. I noticed that I have to push the Parking brake further down in order for it to work. Does anyone know how to adjust the parking brake. I looked in the Chilton Manual and it says its self adjusting. Dealer told me that you can manually adjust it. They weren't helpful in telling me how to do it.
Old 06-09-2004, 06:33 PM
fmtrvt fmtrvt is offline
fmtrvt is a name known to allfmtrvt is a name known to allfmtrvt is a name known to allfmtrvt is a name known to allfmtrvt is a name known to allfmtrvt is a name known to all
The vehicle has disc brakes in the rear, but does utilize a DIH (Drum In Hat) parking brake. The cables no longer have a provision for taking up cable slack. This is done automatically in the pedal assembly. However, the DIH brake still has an adjusting screw for taking up clearance.
I'm going to talk in generalities, as for the life of me I can't remember exactly with your version. There usually is a rubber plug in the backing plate of the DIH. When you pull it out, you will have access to the adjustment screw. Usually only a few notches have to be turned, but you want to expand the shoes out so there is close contact, but no major drag on the wheel. To do that, the rear wheels should be off the ground and the vehicle in neutral. Under this situation, it's best to have a wheel chock or block on both sides of the front wheel so the vehicle does not roll. If you go too far, just back the screw the opposite way.
Here is a picture of what it looks like, but this is from an F-350.
Old 06-09-2004, 06:45 PM
2000Expy's Avatar
2000Expy 2000Expy is offline
2000Expy is gaining momentum as a positive member of FTE.
Post parking brake adjustment
Hi,
From what I could gather in looking at the Ford Service Manual on CD, there is an adjuster inside the area containing the parking brake shoes. That is, remove rear wheels and parking brake drums.
Old 06-10-2004, 12:12 AM
thanks for your help. I could not open up the pic. Is there anything in particular I need to do.
Old 06-10-2004, 06:08 AM
The picture just showed the screw in the assembly. Just pull the plug and just either a drum brake adjusting lever, or a flat blade screwdriver to move the star wheel.
Old 01-07-2013, 05:28 PM
aearch aearch is offline
aearch is starting off with a positive reputation.
emeg brake
this is JUST PLANE PPOOOOOOOORRRRRRRR
ENGINEERING EVER SINGLE ONE FAILS
EVEN IF YOU PUT NEW SHOES AND ADJUST TO
THE EXACT POSITION
IT WILL NOT HOLD THE DEALER SAID PUT A BRICK UNDER THE WHEEL
they are too small to hold the weight of the vehicle
the cable is the problem -it stretches out
the only thing to do is shortern the link under the
drivers door but then they drag its a very bad design
adjusting parking brake drielle 1997-2006 Expedition & Navigator 26 01-22-2016 03:13 PM
How do I adjust the parking brake? bill11012 1999 to 2016 Super Duty 25 01-15-2016 05:02 PM
99' Expedition Parking Brake Adjustment wagonerkl 1997-2006 Expedition & Navigator 2 06-21-2010 10:14 PM
How to adjust park brake Headviking 6.0L Power Stroke Diesel 7 03-30-2010 06:49 PM
How to adjust parking brake 03 exp. frankdude 1997-2006 Expedition & Navigator 7 03-03-2008 02:37 PM
Tags
2000, 2001, adjusting, adjustment, brake, brakes, cable, disc, emergency, expedition, ford, parking, procedure, rear, tighten
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
