1999 Ford Explorer Brake, ABS Problem - Ford Truck Enthusiasts Forums
Old 06-09-2004, 02:21 PM
nocal nocal is offline
nocal is starting off with a positive reputation.
The ABS light came on while driving on the freeway. I checked the fuses, wiring, wheel sensors etc. I do not have an ABS scanner, can a meter be used at the test plug? How do you reset the ABS light? Anyone have information on this problem.
Old 06-09-2004, 11:44 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
Hi nocal and welcome to the forum
You should probably take the Exploder in and get the ABS scanned to at least give you some idea of where to look for the problem. It takes a scan tool capable of reading ABS codes to retrieve them. Apparently the ones that Autozone uses arent capable of that.
To turn the light off you can disconnect a battery terminal for 10 minutes or so and that should clear it, until the next time the problem happens.
Old 06-13-2004, 07:48 PM
ofcbob ofcbob is offline
ofcbob is starting off with a positive reputation.
I found out the hard way. Every shop I have been to charges a $90-100 diagnostic fee and they usually 'throw in' the 1st 1/2hr labor ... last problem I had w/my 99 F250 LD I went and bought the OBDII code reader at the auto parts store. For $100 it diagnosed my exact problem and I saved hundreds on the repair PLUS I still have the code reader. Today I had an ABS light activation and, according to Chilton's, if I use the code reader while the light is on it will give me a trouble code. Chilton's even translates the codes in case your code reader doesn't.
If you are a DIY'er I would definitely invest in the code reader and work from there. Nothing bothers me more than paying a couple hundred bucks to have a sensor cleaned or something similarly simple.
ABS Light on Aussie BrianB Australia Chapter 6 07-26-2013 10:56 AM
ABS light Diesel_Brad 1987 - 1996 F150 & Larger F-Series Trucks 11 10-07-2012 09:59 AM
Help me find why my ABS light is on. khadma 1978 - 1996 Big Bronco 6 12-30-2011 04:14 AM
Help pulling ABS codes? Beastlyforddude 1987 - 1996 F150 & Larger F-Series Trucks 11 02-16-2011 02:54 PM
Rear ABS light wendal 1987 - 1996 F150 & Larger F-Series Trucks 2 12-18-2009 03:12 PM
Tags
1999, abs, activation, brake, brakes, explorer, ford, light, problem, problems, reset, sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
