Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-09-2004, 06:22 AM
Vegas F-150 Vegas F-150 is offline
Vegas F-150 is starting off with a positive reputation.
Question Diagnostic code P0401 Insufficient EGR Flow
My 2001 F-150 came up with this code and I changed the EGR valve cleared the code and it returned 15 miles later. Does any body know what else it could be? I appreciate any help the truck only has 30K miles and the warranty expired 24 May.
  #2 (permalink)
Old 06-09-2004, 10:37 AM
ranger88a ranger88a is offline
ranger88a is starting off with a positive reputation.
You need a dpfe sensor not the egr valve!
__________________
20+ years as a tech. Diesel certified.
  #3 (permalink)
Old 06-09-2004, 01:30 PM
FourthFordTruck FourthFordTruck is offline
FourthFordTruck is starting off with a positive reputation.
If your truck didn't have only 30,000 miles on it, I would take the egr valve back off, remove the throttle body housing, and clean the two egr ports and passage inside the throttle body housing. That is what cleared my low egr flow code. I've read alot of people replace the dpfe for this code and it doesn't help. You have the 4.6 V8? Ranger88 must be right.
Mine was closed up with hard carbon, cleaned at 128,000.
A guy posted a thread the other day, a mechanic wanted $900 to put in a new dpfe, which the guy did himself instead. Code still there. Good luck.
__________________
'87 Bronco II 4x4 XLT, traded in on SportTrac below.
'00 SportTrac-Rife with Problems off showroom floor which couldn't be fixed, sold it.
'99 F-150 Scab 5.4-Totaled R.I.P.
'97 F150 XLT Supercab 4.6L 247,500 - Eats $ daily
'99 Exped. Eddie Bauer 5.4L 131,500-Motor Blew R.I.P.
I think 5 chances are enough. Here's mud in your eye.
  #4 (permalink)
Old 06-09-2004, 02:44 PM
Thanks for all the suggestions. I going to do some cleaning then if that don't work I guess I will be replacing more parts. For FourthFord Truck I have the 4.2 V6. I've only had the truck for 2.5 months so I am not sure how the previous owner treated the truck. The truck is still running strong with no missing or hesitation. Thanks again for the suggestions.
  #5 (permalink)
Old 06-09-2004, 03:18 PM
I'm familiar enough with the 4.2 to know about the egr set up.
The DPFE won't take you long at all.
__________________
  #6 (permalink)
Old 06-16-2004, 02:25 AM
I would like to thank you FourthFord Truck I changed the DPSE sensor, reset the service soon light, and have driven the truck for 200 miles to my success the light has not returned. Thanks again.
  #7 (permalink)
Old 06-16-2004, 10:33 AM
Ranger88a deserves the thanks, but you are welcome Vegas. My submission seems
almost more confusing to me than helpful. Ranger88a was right on.
I meant to say I am not familiar enough with the 4.2 egr set-up.
I will remember the false egr code on lower mileage trucks as possible dpse trouble.
Thanks Ranger88a!
__________________
  #8 (permalink)
Old 06-16-2004, 01:49 PM
No problem, I work on them everyday, glad to help. There are many here who help eachother and many thanks to them also!
__________________
  #9 (permalink)
Old 06-17-2004, 04:16 PM
Thanks to you too Ranger88a. I greatly appretiate it.
  #10 (permalink)
Old 06-17-2004, 07:47 PM
xcopterdoc xcopterdoc is offline
xcopterdoc is starting off with a positive reputation.
check with your dealer on the dpfe... it has an extended warranty. You'll need to give em your vin # and mileage.
__________________
ASE Certified Master Technician
NC Certified Safety Inspector
NC Certified Emissions Inspector
Please no advertising your employer's web site in your sig.
  #11 (permalink)
Old 06-22-2004, 10:34 AM
Elktrekker Elktrekker is offline
Elktrekker is starting off with a positive reputation.
Code not always DFPE
Just to let you know. I got the same code (P0401) on my 97 4.6l F150, and replaced the DFPE sensor right away. Didn't fix the problem, so I'll be cleaning the EGR ports next. A lot of people have said that this code means a bad DFPE sensor, and it's not always true (actually, it seldom is from what I gather). Now I'm getting a P0302 (#2 misfire) code, which I think might be related. I've replaced the coil packs and the plugs, and will replace the wires next.
  #12 (permalink)
Old 06-22-2004, 10:47 AM
On a high mileage 4.6, I would always go with the egr ports and valve.
I believe every 4.6 will eventually have this problem.
On a low mileage 4.2, I'd go with the dpfe.
__________________
  #13 (permalink)
Old 06-22-2004, 06:03 PM
hugepettyfan hugepettyfan is offline
hugepettyfan is starting off with a positive reputation.
Where is the most inexpensive place to purshase a DPFE sensor? My local dealer wants +/- $100
  #14 (permalink)
Old 06-22-2004, 06:21 PM
Got mine on ebay
There's a couple due to close in the next day or two. Just do a search for Ford DPFE and you'll find them.
  #15 (permalink)
Old 06-22-2004, 06:55 PM
freak98's Avatar
freak98 freak98 is offline
freak98 is starting off with a positive reputation.
I just had to replace the DPFE sensor on my 99 rangertoday.Is this a common problem?
Tags
150 , 46l , 99 , check , clean , code , egr , engine , exhaust , f150 , flowmaster , ford , light , p0401 , ports , reader , valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
