1988 4WD Manual Hub Spindle Removal
Are there invisible bots that hold on the spindle? I've been trying to remove mine for the past couple of weeks. They won't budge on either side.
I don't own an official spindle puller but I've used various items to pull and still nothing. Pounding and heating does nothing.
1988 Ford Ranger 4WD manual hubs V6.
Spray the area just outside of where the bolts were with pb blaster or what ever you like, get about a foot long hard piece of 2x4, lay it on the end, where the threads are, bash it with the biggest hammer you can handle with one hand. One bash down, then one from the bottom up. You should see it start to separate, insert a flat screwdriver in the gap, then hit from the bottom, keep at it, it will come off. Then wire brush real good, and use anti seeze when putting it back on.
Steel Toy
17
03-02-2011 12:21 AM
mialo1
11-09-2003 12:56 AM
