v10 vs diesel - Ford Truck Enthusiasts Forums
v10 vs diesel
Old 08-09-1999, 11:01 PM
MBernat MBernat is offline
MBernat is starting off with a positive reputation.
v10 vs diesel
which is better, v10 or diesel, and why?
Old 08-10-1999, 06:49 PM
Fred
Guest
Posts: n/a
v10 vs diesel
I'll try and break things into pros and cons
Gas- con- high fuel consumption, especially when pulling, not much torque in reserve for mountains.
Gas- pro- quieter, cheaper oil changes 7qts, but more often
Gas- con- needs "tune-ups", ie plugs, especially when towing, may need more than at factory recommended changes. On the v10, they are a bitch to change
Diesel- pro- better mileage, much more torque at lower rpms.
Diesel- con- noise, if you don't like it, more expensive oil changes up to 16 qts, at longer intervals though
Diesel- pro- has only fuel and air filters to change as required.
Diesel- pro- normally will outlast a gas motor under severe usage.
For any kind of serious towing, I'd get a diesel powered truck, the extra power, better mileage and the longer service intervals are a major plus.
Old 08-21-1999, 07:31 AM
Deen
Guest
Posts: n/a
v10 vs diesel
I think the question boils down to how much extra money you want to spend and how long do you plan on keeping the truck. I too contemplated on gas or diesel. Figure on how many miles you drive each year and then figure the difference between the gas engine getting 12 MPG and the Diesel getting 16 MPG (I know others claim higher/lower milage...depends on who you talk to). When I did some figuring it would take me 8 years to reach the break even point in the extra cost of buying a diesel, thats assuming no breakdowns or rebuilds. To rebuild the fuel system on a Ford diesel runs $3000-3500 (PSD), I can rebuild my 460 three times for that amount if I do most of the work myself. People claim 300,000-400,000 before major rebuilds for diesels but when I was looking at used trucks I saw a number of adds claiming "recently rebuilt" engines and they were in the 1990 to 1995 range. The diesel will definetly have more torque and towing power and that alone may justify spending the extra $4000-$5000 in purchasing price to you...besides they are "in" and that alone will give you bragging rights
Old 03-18-2000, 12:35 PM
fascaps fascaps is offline
fascaps is starting off with a positive reputation.
v10 vs diesel
Im not so sure i agree with all of the above.
First the newer 7.3 direct injected motors get much better gas milage than the older direct injected or 6.9 motors.
Ive been around quite a few of these and to rebuild a one inside of that low of milage means the person just plain did not take care of the truck.
Personally I own the diesel motor. LOVE IT and that was the easy choice the hard one was if I wanted a extended cab or crew cab.
If your towing a heavy load hands down diesel is the way to go if not consider gas but even If I were not towing Id own the PSD just for the durability of the motor and with amsoil and some add on filters I dont even have to change my oil that often!
Old 09-24-2000, 10:09 AM
turbotime turbotime is offline
turbotime is starting off with a positive reputation.
v10 vs diesel
Go Powerstroke for milage,durability,sounds better that the v10 that sounds like a sick 6 cylinder, Just change the oil and keep on going ..I get 17 in my 250HD 4x4 powerstroke and I hear people all the time saying they re getting 6.5 to 11 in a gas V10. V10 is cheaper to purchase new and there is a reason. drive both
Old 09-24-2000, 04:25 PM
deleontow deleontow is offline
deleontow is starting off with a positive reputation.
v10 vs diesel
Let me put it in a simple format. People who drive trucks for a living prefer the diesel. Gas does not have the durablilty of a diesel. Lower maint cost and more reliabilty. The other factor in our business is that our trucks many times will idel for long periods in extreme hot temps, diesels we dont have to worry about overheating at idel, were as gas we can not let them idle for long periods.
Been doing this for many years now and have seen the gas vs diesel a lot. You wont find to many tow trucks that are gas. That will tell you a lot.
Dave
http://a2ztowing.homestead.com/a2ztowing.html
Old 09-27-2000, 09:16 AM
bgodkin bgodkin is offline
bgodkin is starting off with a positive reputation.
v10 vs diesel
Old 10-07-2010, 09:49 AM
brandonward brandonward is offline
brandonward is starting off with a positive reputation.
v-10 vs PSD
I'm currently looking for a Ford F-250 or 350 crew cab. I have read several post regarding V-10 vs PSD. The problem that I'm having trouble is which to buy? I want to find one 1999-2002, because that is my price range. My needs are; I go wood cutting about three times a year and then the truck would be used for projects around the house. I'd rather have to much truck now, because who know what I might need the truck for in the future. Any advice if I should buy a v-10 or the PSD would be helpful?
Thanks
Old 10-07-2010, 09:55 AM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
Quote:
Thanks
Here is a couple pages to read about this. I don't think you will get much from this forum, being it is a diesel forum.
Click on this LINK.
Old 10-07-2010, 10:01 AM
00Dave's Avatar
00Dave 00Dave is offline
00Dave is gaining momentum as a positive member of FTE.00Dave is gaining momentum as a positive member of FTE.
Hey brandonward! Welcome to FTE! I looked in your profile info and it shows your in Idaho, correct? This is a really old thread, but opinions probably won't have changed much. I won't debate the engine preferences. Each person likes what they like. I like diesels so I found one. It will be cheaper to purchase a v10 from what I have seen around my parts. I don't think you will be unhappy with whatever choice. Good luck!
Old 10-07-2010, 11:11 AM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.
Quote:
Click on this LINK.
YEAH. I managed to get 8000th post in this thread and I am going for 10,000 th
Old 10-07-2010, 11:55 AM
Quote:
I think the crap they come up with is so funny. The 5.4 will pull as good as a PSD.
Old 10-07-2010, 12:20 PM
Franko72's Avatar
Franko72 Franko72 is offline
Molon Labe
Franko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud of
Rick , my best friend is a die hard chevy gas guy, and he hates diesels. He tries and tries to convince me why gassers are better.
But when I ask him to prove the facts, all he can come up with is "diesels stink and they're loud".....
Thats the reason I have that sticker on my rear window...
Old 10-07-2010, 12:44 PM
BDalton's Avatar
BDalton BDalton is offline
BDalton is gaining momentum as a positive member of FTE.BDalton is gaining momentum as a positive member of FTE.
Holy eleven year old thread Bat Man!
Old 10-07-2010, 12:48 PM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Woo hoo, over 10 years old! I do believe this is the oldest thread I've ever seen brought back to the top!
All kidding aside, check out that link Rick posted for you. Just remember, there is a lot of BS slinging going on in that thread too!
Stewart
Looking at Vinford 1999 to 2016 Super Duty 13 12-03-2014 05:39 PM
Accelerator Pedal V10 Compatible with 7.3? Atc210 Excursion - King of SUVs 8 10-29-2014 08:27 PM
v10 to diesel bigbadassfords Engine Swaps 8 11-10-2013 09:33 PM
v10 vs pds oem exhaust AllAboutDaZ Modular V10 (6.8l) 5 10-12-2013 06:05 PM
new 6.2 vs old 3v v10 twigsV10 6.2L V8 21 07-05-2013 12:48 AM
Tags
1999, 73, compared, cost, desel, diesel, dtruks, f350, ford, gas, rebuild, v10, v10versusdiesel, versus, vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
