6.9 DSL TRANS SWAP
6.9 DSL TRANS SWAP
I just spent about an hour chatting with a fellow who has tried all sorts of options on transmissions and motor's from the ford series. I was particularly interested in the zf 5 speed/6.9 hookup. He said he has tried this swap. Problem #1 ...the ZF apparently has needle bearings at the input shaft. When hooked up to the diesel, these don't hold up by themselves. The most early diesels with the 5 speed got recalled or else fixed. The fix wasn't to put ball bearings in as one might expect but to add a harmonic balancer otherwise known as a dual flywheel to the back of the engine. Problem # 2... these harmonic balancers (or dual flywheels) are very expensive new... $500 . Problem 3. There are aparently some plastic parts involved with this harmonic balancer that if the clutch heats up from slipping too much... they melt. Apparently this fellow was under the impression that all zf tranny's had this needle bearing problem and thus the harmonic balancer. His suggestion was to go with a 4 speed t-19 and use a spicer tri-speed gear box. This was aparently made in the 50's thru the 70's for midweight trucks (F600, International 1700, etc.) He aparently put one in a 2 wheel drive and has 3 gears four speeds to choose from. He didn't know how to hook this up to a 4X4 with the transfer case, so he suggested one of the two speed overdrive units.(u.s. gear...etc)
Thought I'd share this info... I Would apreciate other comments concerning such transmission swaps and related items.
Tony
Tony
Burninoil
01-30-2013 04:37 PM
frankenstein
30
03-11-2006 08:20 PM
