E4OD to C6 conversion? - Ford Truck Enthusiasts Forums
Old 10-15-2000, 08:36 AM
jeepnford jeepnford is offline
jeepnford is starting off with a positive reputation.
Does anyone know if you can replace the junk overdrive E4OD with a C6 Without a lot of problems?
Old 10-24-2000, 04:12 PM
deleontow deleontow is offline
deleontow is starting off with a positive reputation.
It is possible but not on the PSD, what are you trying to replace, Year make model ect.
Dave
http://a2ztowing.homestead.com/a2ztowing.html
Old 10-27-2000, 09:18 PM
DIESELSITE's Avatar
DIESELSITE DIESELSITE is offline
Former Vendor
DIESELSITE is gaining momentum as a positive member of FTE.
C6 to e4od swap Blind Driver 1987 - 1996 F150 & Larger F-Series Trucks 1 02-29-2016 11:43 AM
E4OD or C6 dakotajeep Clutch, Transmission, Differential, Axle & Transfer Case 3 02-25-2008 07:07 AM
e4od \c6 gear ratios mike86f350 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 01-27-2008 01:37 AM
What is the diffirencein E4OD and 4R100 dinikin 1994.5 - 1997 7.3L Power Stroke Diesel 1 02-10-2007 11:30 AM
C6 vs E4OD ? Shiny62 Clutch, Transmission, Differential, Axle & Transfer Case 1 09-25-2005 05:18 PM
Tags
c6, conversion, convert, converting, diesel, e40d, e4od, ford, replace
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
